Rubber in the bonnet channel.
https://www.ausmini.com/forums/viewtopic.php?f=2&t=64199
Author:  ryan [ Mon Jul 05, 2010 5:09 pm ]
Post subject:  Rubber in the bonnet channel.
I have seen some car with a rubber strip along the back channel of the engine bay, where the bonnet sits.
Is this a factory thing?
What was the purpose?
Does it cause rust?
Is it available or do you just buy it from a rubber shop? What size is it?
Author:  winabbey [ Mon Jul 05, 2010 5:17 pm ]
It is a standard factory item:
http://www.minisport.com.au/prod1372.htm
or get your own from Clark Rubber.
Author:  Morris 1100 [ Mon Jul 05, 2010 5:58 pm ]
There was two different types, one for the roundie and one for the clubbie style.
Author:  NG [ Mon Jul 05, 2010 6:21 pm ]
what does it do?
Author:  Harley [ Mon Jul 05, 2010 6:24 pm ]
Cuts noise, vibration, water splashback, and in the case of most rovers: the rust.
:D
Author:  Morris 1100 [ Mon Jul 05, 2010 6:44 pm ]
NG wrote:
what does it do?
It stops oil from getting sucked from the engine bay onto the windscreen. :wink:
Author:  Kennomini [ Mon Jul 05, 2010 7:08 pm ]
Adds weight, run without it.
Author:  NG [ Mon Jul 05, 2010 7:11 pm ]
lol shush you.
clark rubber sells this?
Author:  drmini in aust [ Mon Jul 05, 2010 7:13 pm ]
NG wrote:
lol shush you.
It's just a rectangular section sponge, Clark rubber should have it, I got mine from Grippy Rubber in Silverwater (Sydney).
1M is enough, then trim it to fit in.
Author:  Morris 1100 [ Mon Jul 05, 2010 7:25 pm ]
The roundies have the square section rubber but the clubman has the h shaped one that fits on the front lip of the gutter.
Author:  ryan [ Tue Jul 06, 2010 6:49 pm ]
$3.29 well spent.
It cut down a shocking vibration that only happened at idle.
