It is currently Thu Aug 21, 2025 11:10 am
 Post subject: pistons
PostPosted: Fri Jul 09, 2010 12:44 pm
Have come across set of acl pistons @rings+60. Would like to know what these pistons are like to run in a 1275
PostPosted: Fri Jul 09, 2010 12:46 pm
Is there any numbers/letters stamped on the top of the piston?
Can you measure the diameter of the piston?
Mini, its in my blood........
PostPosted: Fri Jul 09, 2010 12:59 pm
what i can make out no are rp 2272 .60 no other markings
PostPosted: Fri Jul 09, 2010 1:14 pm
ACL's pistons were OK, but they don't make any now. :cry:
PostPosted: Fri Jul 09, 2010 1:19 pm
came across a new set that as not been used, come with rings and pins also are they worth buying thanks (cheap )170
PostPosted: Fri Jul 09, 2010 1:23 pm
That's pretty good but for another $30 you can get Hypatecs complete, which are a still currently available piston.
Lindsay Seibler has them, also Minisport SA.
http://www.minisport.com.au/category5_1.htm
Users browsing this forum: fuzzy-hair-man and 66 guests
