pistons https://www.ausmini.com/forums/viewtopic.php?f=2&t=64277 |
Author: | crabby [ Fri Jul 09, 2010 12:44 pm ] |
Post subject: | pistons |
Have come across set of acl pistons @rings+60. Would like to know what these pistons are like to run in a 1275 |
Author: | justincase42 [ Fri Jul 09, 2010 12:46 pm ] |
Is there any numbers/letters stamped on the top of the piston? Can you measure the diameter of the piston? |
Author: | crabby [ Fri Jul 09, 2010 12:59 pm ] |
what i can make out no are rp 2272 .60 no other markings |
Author: | drmini in aust [ Fri Jul 09, 2010 1:14 pm ] |
ACL's pistons were OK, but they don't make any now. ![]() |
Author: | crabby [ Fri Jul 09, 2010 1:19 pm ] |
came across a new set that as not been used, come with rings and pins also are they worth buying thanks (cheap )170 |
Author: | drmini in aust [ Fri Jul 09, 2010 1:23 pm ] |
That's pretty good but for another $30 you can get Hypatecs complete, which are a still currently available piston. Lindsay Seibler has them, also Minisport SA. http://www.minisport.com.au/category5_1.htm |
