No it's NOT the classic Lynx `swan neck' (which is higher than it is long).
It looks similar to, but not quite the same as a Redline 3005/short Warneford one I use.
It should fit in without hacking, as long as you use either an offset filter (Ramflo etc) or short trumpets with sock filters.
Lynx swan neck (pic from Graham Russell's's article on Minimania forum)
http://www.minimania.com/images/articles/russell_3h.jpg
This whole article is a good read, see
http://www.minimania.com/web/DisplayID/ ... ticleV.cfm
