1071 wrote:
I don't see why that wouldn't work. All you need to do is bridge the rubber mounts. The electrons just need to flow from the engine to the body (or is the other way round??
. So as long as the earth lead allows this it doesn't really matter where its attached.
Cheers, Ian
Yeah problem is you're just bridging the engine mount to the subframe, and there's no guarantee that the subframe is 100% earthed/grounded. Just as easy to put it to the inner guard which is guaranteed to be ground, as the battery earth strap in the boot is also connected to the body.
Jacob
'72 Clubman Van - 1022cc, 295 head, 731 cam - Daily Driver
