Bit of Bling but linkage & Spring? https://www.ausmini.com/forums/viewtopic.php?f=2&t=64287 |
Author: | gafmo [ Fri Jul 09, 2010 8:43 pm ] |
Post subject: | Bit of Bling but linkage & Spring? |
well I'v been of air for two weeks but have finished a few things here is a Bling 1 1/2 HS6 Carb. Doesn't come up to well in this pic, while not spot on this pic does not do it justice ![]() As you can see nothing is fully bolted up (Dry fit) at this stage as I had to purchase the Jet bearing Locking nuts & springs. While I was their I asked if my linkage was correct. Answer was Yep but once fitting I don't have full travel of the Jet. Where have I gone wrong ![]() |
Author: | mini maxx [ Fri Jul 09, 2010 8:48 pm ] |
Thats Purdy Gaf bit i reckon its not gunna work to well with your finger violating its oriface like that....do you feel dirty ![]() ![]() |
Author: | Fiji [ Sat Jul 10, 2010 8:30 am ] |
i think i can see a speck of dirt on that spring washed.. better start again. looks awesome as usual. i cant wait to see what it looks like when ur get it all together. |
Author: | scotta_74 [ Sat Jul 10, 2010 3:31 pm ] |
Gaf, the return spring underneath the linkage is not seated properly. I had this issue when I did mine, you need to screw the bolt in a couple of more turns then hook the spring onto its retainer. |
Author: | gafmo [ Sat Jul 10, 2010 3:49 pm ] |
Great spotting their Scott.. I did find that as it was all only loose fitted. I have oiled it all and tightened and Cented the Jet also ![]() Ever wondered what a Clear Coated Engine look like in a Black Engine Bay. Jut a few things to do now like finding a Alternator rather than the gen ![]() |
Author: | micowen [ Sat Jul 10, 2010 4:38 pm ] |
wow! What did you clear coat it in? |
Author: | MiniKit [ Sat Jul 10, 2010 7:39 pm ] |
Post subject: | Re: Bit of Bling but linkage & Spring? |
gafmo wrote: ![]() That's a fantastic photo, very artistic.. ![]() |
Author: | aaron [ Sat Jul 10, 2010 7:47 pm ] |
gafmo wrote: Ever wondered what a Clear Coated Engine look like in a Black Engine Bay. Jut a few things to do now like finding a Alternator rather than the gen Pretty sure I have a few, Unknown condition of course, but you can only but give them a go. ![]() |
Author: | gafmo [ Mon Jul 12, 2010 4:00 am ] |
That would be brilliant Aaron...are you home saturday |
