Acewell installation?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=64383
Author:  blake12345 [ Tue Jul 13, 2010 4:30 pm ]
Post subject:  Acewell installation?
hi,
just wondering if this kinda thing
http://www.acewell-meter.com/c0_1.php?pid=5&bid=11
can be mounted to an aseries engine and if so how hard is it?
Thanks Blake
Author:  WasabiPimpNinja [ Tue Jul 13, 2010 4:56 pm ]
Looks like it uses a magnet type speed sensor set up to calculate the speed, but being desinged for a bike would work off the wheel (like those ones you get for your deadly treadly). I guess it could be made to fit a car, you'd need to attach it to the wheel and mount the sensor somewhere where it wouldn't interfere with steering. I guess you could run it on the back? So technically, yes, it would work. It uses a spark sensor to work out the RPM, so you'd have to make sure it was compatible with a 4cyl 4 stroke. Considering there are 4cyl 4stroke bikes out there, I'm guessing this would be ok. I doubt very much if it would be legal as your only speedo/odometer, but you'd have to check with the authorities on that.
The real question is, are you going to be doing 300kmph at 11,900rpm?
Author:  crazy bob [ Tue Jul 13, 2010 6:05 pm ]
I think that it wouldnt be legit if it is your only odometer, pretty sure yourmeter need to be able to clock more than 99,999 km.
Author:  superSeven [ Tue Jul 13, 2010 6:51 pm ]
I actually quite like these
http://trailtech.net/vapor.html
would prefer it over the acewell.
edit: damn no fuel gauge..
oh the acewell does 99,999 kms for odometer.
Author:  blake12345 [ Tue Jul 13, 2010 9:00 pm ]
mmm thats true crazy bob. Im just wanting to get some new gauges and thought something like this would be abit different.
Thanks Superseven, i actually dont mind that one either. Id be looking at outting other gauges in aswell so no fuel gauge is no big deal.
And i can only wish that i was doing 300kph @ 11900rpm but no my car has only ever been up to 135kph@5500rpm (on a dyno) so i cant quite see it reaching 300 but it would be nice!!!!!
Thanks
Blake
Author:  superSeven [ Tue Jul 13, 2010 9:49 pm ]
My mini only goes up to 99,999kms on the odometer I believe
Author:  bnicho [ Wed Jul 14, 2010 12:16 pm ]
If your Mini is pre 1980-something then you only need to have an odometer that goes up to 99,999km to meet ADR's.
I laugh every time I see a rough Mini on eBay with a "genuine 58,000km" or similar claim. It could be 558,000km, except the odometer would die before it turned that many times. :)
Author:  MrDerrickC [ Thu Jul 15, 2010 12:47 pm ]
I have a Acewell 1500, more simple unit.
Pretty easy to install actually, using a hall sensor for speedo pickup.
I bought mine from here since it was local
http://s3performance.com.au/acewell-150 ... p-177.html
