It is currently Mon Aug 04, 2025 6:04 pm
PostPosted: Tue Jul 13, 2010 8:30 pm
hi all,,
ok,,, some of you may know that i make primary gear thrust washers, sooooo, i`m in the middle of a big batch of them at the moment
if you`re in need of a "special" thickness & you can work out exactly what that thickness is within the next day or 2... then let me know cause i`m right in the middle of it
my main stream ones are from 120thou up to 125thou,,, (They`re getting pretty normal these days) but i have already machined up quite a few at 125thou & 126thou (just in case)
but if you need a 130thou or whatever,,, then let me know while i`m on the machine
setting this thing up to do another run is an absolute pain in the Ar$e to be honest so get in while i`m already set up,,, otherwise miss out till maybe next year cause i won`t be doing another run of them for a long while
ok???
ph 0407 135 656
sorry if this is in the wrong place mods,,, but it`s not really a "for-sale" advert,,, just a "Heads-up" to anyone smart enough to know when to strike,,, & yes, the iron is hot right now :-)
Edit,,,---> & Ken N,,, your`s are already in the post, you should see them tomorow, thanks again mate... Oh & i threw another spare one in for you , just cause you`re so nice to me :-)
Users browsing this forum: No registered users and 117 guests
