1275 Primary gear thrust washers https://www.ausmini.com/forums/viewtopic.php?f=2&t=64388 |
Author: | TheMiniMan [ Tue Jul 13, 2010 8:30 pm ] |
Post subject: | 1275 Primary gear thrust washers |
hi all,, ok,,, some of you may know that i make primary gear thrust washers, sooooo, i`m in the middle of a big batch of them at the moment if you`re in need of a "special" thickness & you can work out exactly what that thickness is within the next day or 2... then let me know cause i`m right in the middle of it my main stream ones are from 120thou up to 125thou,,, (They`re getting pretty normal these days) but i have already machined up quite a few at 125thou & 126thou (just in case) but if you need a 130thou or whatever,,, then let me know while i`m on the machine setting this thing up to do another run is an absolute pain in the Ar$e to be honest so get in while i`m already set up,,, otherwise miss out till maybe next year cause i won`t be doing another run of them for a long while ok??? ph 0407 135 656 sorry if this is in the wrong place mods,,, but it`s not really a "for-sale" advert,,, just a "Heads-up" to anyone smart enough to know when to strike,,, & yes, the iron is hot right now ![]() Edit,,,---> & Ken N,,, your`s are already in the post, you should see them tomorow, thanks again mate... Oh & i threw another spare one in for you , just cause you`re so nice to me ![]() |
