Dented Muffler https://www.ausmini.com/forums/viewtopic.php?f=2&t=64406 |
Page 1 of 2 |
Author: | jordy.... [ Wed Jul 14, 2010 9:27 pm ] |
Post subject: | Dented Muffler |
Hi, ive got a 'unknown' muffler and im very happy with it and the noise it makes (and the neighbours it annoys ![]() ![]() But this arov i took it off the car and noticed that there is a large dent on the muffler casing it-self, around 1/2'' deep and 2 inches round! Would this be effecting the preformance output (not that it matters that much!) or is this a hazard? and would it be ok to get rego'd considering its on the bottom side in clear line of view?? cheers jordy.... |
Author: | WasabiPimpNinja [ Wed Jul 14, 2010 9:48 pm ] |
So long as it is not cracked/leaking it should be fine for rego. It wont affect performance as the casing on the outside does not interfere with the pipe through the inside, so the flow would not be altered. I've dented a few, no biggy. Cheers, |
Author: | gafmo [ Wed Jul 14, 2010 10:11 pm ] |
Dented Muffler I would not worry at all unless as said above its got a crack in it but thats unlikely. Most of the time their is a join just before the muffler and you maybe able to spin the muffler around unless its a side exit. A dented muffler for rego..I would not worry..you would have more dents in the floor than the muffler that would need more closer inspection |
Author: | blueminivan [ Wed Jul 14, 2010 10:19 pm ] |
A Key-banger will pop it out. And probably a whole lot more. ![]() |
Author: | winabbey [ Thu Jul 15, 2010 11:53 am ] |
blueminivan wrote: A Key-banger will pop it out.
Please explain ![]() ![]() |
Author: | Mick [ Thu Jul 15, 2010 12:05 pm ] |
I used to do key-bangers in my 1980 Holden Rodeo diesel. You turn the ignition off and turn it back on after a while. The exhaust goes BANG! In the case of the diesel it would puff a large white cloud of half vaporised diesel out of the exhaust and into the tail sitter's air conditioning. In the case of my mate's Dad's Kingswood it would split the exhaust system open like a banana peel. I am pretty sure it didn't do the Rodeo any good either.. |
Author: | Morris 1100 [ Thu Jul 15, 2010 5:17 pm ] |
A certain un-named forum member had to return a rented Toyota Coaster bus with a destroyed muffler and managed to be on a plane before the rental company found it. ![]() ![]() ![]() I used to blow up Holden mufflers for fun when I was younger. ![]() |
Author: | Bubbacluby [ Thu Jul 15, 2010 7:08 pm ] |
So is this key banger thing easy to do? I mean i turn cars on and off all the time and nothing happens, im curious as to how i can do it, if i wanted to?? |
Author: | Morris 1100 [ Thu Jul 15, 2010 7:18 pm ] |
Bubbacluby wrote: So is this key banger thing easy to do? I mean i turn cars on and off all the time and nothing happens, im curious as to how i can do it, if i wanted to?? It works by the fuel getting pumped through the motor into the muffler where it ignites once you turn the key back on.
So find a long downhill stretch (the main street of Cowra is a good example) and just turn the key off and let the motor keep spinning in gear. Give the accelerator a few extra kicks if the carby has accelerator pumps to throw some extra fuel into the motor and then when you get to the bottom of the hill turn the key on and order a new muffler. It will not work with injection and does not work very well at all with SUs but an old Holden it works well! If you just turn the key off for about five seconds and pump the accelerator you might get a good POP. But if you coast for a mile or so it might blow the exhaust. ![]() |
Author: | mini maxx [ Thu Jul 15, 2010 7:26 pm ] |
Morris 1100 wrote: I used to blow up Holden mufflers for fun when I was younger. ![]() You too ![]() ![]() ![]() |
Author: | blueminivan [ Thu Jul 15, 2010 7:31 pm ] |
Yes. My old Datsun 720 ute had a few loud trips back into town after being too greedy. ![]() |
Author: | Morris 1100 [ Thu Jul 15, 2010 7:36 pm ] |
mini maxx wrote: Morris 1100 wrote: I used to blow up Holden mufflers for fun when I was younger. ![]() You too ![]() ![]() ![]() I was once going down the Highway and flicked the key off and gave a couple of pumps. Just before I was about to turn it on I saw a little old lady on the footpath so I knew I couldn't do it (weak *unt ![]() Funny how the back seat always looked crooked after that! ![]() ![]() |
Author: | gafmo [ Thu Jul 15, 2010 8:00 pm ] |
I use to do it also in the RX4 but it was even easier. Rev it up to 11,000 and just leave it in gear and let the revs die. I spat three mufflers off and my favorite placed to do it was rite out the front of Westfields Parramatta. I made the mistake once and a cop car was two cars behind me. I guess I expected the canary. Thursday night was the best because you saw the flash also from the exhaust |
Author: | mini maxx [ Thu Jul 15, 2010 8:12 pm ] |
Bunch of Hoons aint we ![]() |
Author: | Morris 1100 [ Thu Jul 15, 2010 8:15 pm ] |
gafmo wrote: I use to do it also in the RX4 but it was even easier. Rev it up to 11,000 and just leave it in gear and let the revs die. I spat three mufflers off and my favorite placed to do it was rite out the front of Westfields Parramatta. I made the mistake once and a cop car was two cars behind me. I guess I expected the canary. Thursday night was the best because you saw the flash also from the exhaust
Bloody rotaries! I once did a 24 hour endurance race and when I went to bed after doing a long night time driving stint I could still hear the rotaries in my sleep. Not only that I could still see the flames out the exhaust in my sleep! ![]() |
