It is currently Tue Aug 05, 2025 11:28 am
PostPosted: Thu Jul 15, 2010 7:13 am
Hi,
I'm looking to get some steel to practise my welding and eventually to put in some small patches in the floor.
What thickness should I be looking for?
Where can I buy small amounts of steel sheet in Sydney? Somewhere around Ryde or Silverwater would be perfect.
1970 Mini K
PostPosted: Thu Jul 15, 2010 3:40 pm
I usually buy mine from Edcon at Brookvale but there are a few suppliers around Suppliers around Sydney. Just Google "Sheet steel suppliers sydney"
I think it is about .8 or .9 mm, but I usually take a small piece from the area I am repairing and get them to match it. Also most suppliers have an off cuts bin you can get some small pieces from which usually works out cheap.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Thu Jul 15, 2010 5:39 pm
Find a road side collection of stuff people are throwing out and get a couple of washing machines. Then cut the panels off with a grinder, so then you can practice your grinding AND welding. :D
PostPosted: Thu Jul 15, 2010 5:54 pm
Thanks heaps. I might head over there some time, Brookvale is'nt too bad from work. I can't find much else online. In the Yellow pages I found Southern Steel and Mascot Steel but they are also a bit far.
:lol: :lol: :lol:
I love it.
1970 Mini K
PostPosted: Thu Jul 15, 2010 7:01 pm
What about filing cabinets?? Would they be the right kind/thickness of steel?
Probably pick some up on council clean up s as well - or if you want to buy some old ones, give Reverse Garbage at Marrickville a call, they usually have some for about $20-30
PostPosted: Thu Jul 15, 2010 8:01 pm
I measured the floor of my 1964 850 (with a micrometer) when I welded repair panels in. They were 1.6mm back then (before rust).
I think later Oz floors are a bit thinner.
UK floor repair panels are only 1.0mm thick, no wonder Minis rust out fast over there. :lol:
I used 1.5mm zincseal sheet for floor patches, it welds OK and lasts longer than plain steel.
Last edited by drmini in aust on Thu Jul 15, 2010 8:03 pm, edited 1 time in total.
PostPosted: Thu Jul 15, 2010 8:02 pm
if you want there is a washing machine of the side of the road at
Charles st, carlingford, very close to the silverwater area you were looking for sheet stock. I saw it this evening.
ANY SEA ANY TIME
PostPosted: Thu Jul 15, 2010 8:38 pm
Hmm! I obviously need to measure my panels and not guess. :?
1969 Cooper "S"
1967 Mini Deluxe
Users browsing this forum: Bing [Bot] and 91 guests
