It is currently Sun Aug 10, 2025 2:43 am
 Post subject: roundie beaver panel.
PostPosted: Thu Jul 15, 2010 9:37 pm
Just a simple one for you all.
Is the beaver panel off a roundie structural?
Or is it more of a cosmetic item also designed to catch mud and crap? :lol:
mooo, I'm a pig!
PostPosted: Thu Jul 15, 2010 9:53 pm
IMO it's structural, but you can box it in underneath if you like. Or drill some dirty big `oles in it to let the air and mud out. :P
PostPosted: Thu Jul 15, 2010 10:06 pm
Those rust holes are good for smuggling contraband across the border, you can hide small refugees in there :lol:
PostPosted: Thu Jul 15, 2010 10:16 pm
okay then, another question.
Is it just bolted on with the bumper, or spot welded as well?
mooo, I'm a pig!
PostPosted: Thu Jul 15, 2010 10:17 pm
Spot welded, bugga to grind off
PostPosted: Thu Jul 15, 2010 10:20 pm
DAMM THOSE SPOT WELDS!! (shakes fist angrily!)
mooo, I'm a pig!
PostPosted: Thu Jul 15, 2010 10:27 pm
i didnt box mine in when i did it (corners that is), made it so water couldnt get trapped in the corners
PostPosted: Thu Jul 15, 2010 10:42 pm
PostPosted: Fri Jul 16, 2010 9:03 pm
am i dreaming, or were the beavers on early 850s not boxed? if so, why were they boxed? doesn't that just create a major rust area :lol: or perhaps for structural reasons???
Saxon Green 850: http://www.ausmini.com/forums/viewtopic.php?t=62641
Nightfire Red 850: http://www.ausmini.com/forums/viewtopic.php?t=66555
PostPosted: Fri Jul 16, 2010 9:17 pm
The bottom bolt for the fuel tank attaches right next to the vertical panel that boxes in the corner. It would stiffen up the boot floor in that area a fair bit.
I would box it.
PostPosted: Fri Jul 16, 2010 11:38 pm
At what point did they start to box this panel in?
Sports, do you have an answer??
