roundie beaver panel. https://www.ausmini.com/forums/viewtopic.php?f=2&t=64420 |
Author: | micowen [ Thu Jul 15, 2010 9:37 pm ] |
Post subject: | roundie beaver panel. |
Just a simple one for you all. Is the beaver panel off a roundie structural? Or is it more of a cosmetic item also designed to catch mud and crap? ![]() |
Author: | drmini in aust [ Thu Jul 15, 2010 9:53 pm ] |
IMO it's structural, but you can box it in underneath if you like. Or drill some dirty big `oles in it to let the air and mud out. ![]() |
Author: | mini maxx [ Thu Jul 15, 2010 10:06 pm ] |
Those rust holes are good for smuggling contraband across the border, you can hide small refugees in there ![]() |
Author: | micowen [ Thu Jul 15, 2010 10:16 pm ] |
okay then, another question. Is it just bolted on with the bumper, or spot welded as well? |
Author: | mini maxx [ Thu Jul 15, 2010 10:17 pm ] |
Spot welded, bugga to grind off |
Author: | micowen [ Thu Jul 15, 2010 10:20 pm ] |
DAMM THOSE SPOT WELDS!! (shakes fist angrily!) |
Author: | DTrain [ Thu Jul 15, 2010 10:27 pm ] |
i didnt box mine in when i did it (corners that is), made it so water couldnt get trapped in the corners |
Author: | Hanra [ Thu Jul 15, 2010 10:42 pm ] |
Author: | mini_fanatic [ Fri Jul 16, 2010 9:03 pm ] |
am i dreaming, or were the beavers on early 850s not boxed? if so, why were they boxed? doesn't that just create a major rust area ![]() |
Author: | Morris 1100 [ Fri Jul 16, 2010 9:17 pm ] |
The bottom bolt for the fuel tank attaches right next to the vertical panel that boxes in the corner. It would stiffen up the boot floor in that area a fair bit. I would box it. |
Author: | 850 GT [ Fri Jul 16, 2010 11:38 pm ] |
mini_fanatic wrote: am i dreaming, or were the beavers on early 850s not boxed? if so, why were they boxed? doesn't that just create a major rust area
![]() At what point did they start to box this panel in? Sports, do you have an answer?? |
