hey i'm going to buy a new 2nd gear.
my one at the moment is fine but i want to replace it with a new one for piece of mind as i'm about to strip it.
are these gears as good as the original cast? anyone had problems with these?
if i replace 2nd gear should i replace anything else. with a new cast part?
the box has just been rebuilt, we used the same gear set though looked good.
http://www.minispares.com/Product.aspx? ... 502&title=
Will pull the gears before ordering or check with my mechanic.
Just wanting to know the strength is? I would prefer a new gear
Then use the 16yr old one in there
And it's cheap as!
