Displacer safe to use?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=64560
Author:  1018cc [ Thu Jul 22, 2010 7:52 am ]
Post subject:  Displacer safe to use?
I'm just wondering if I should continue to use this hydrolastic displacer. This was the one on the front passenger side so it has spent its whole life with water possibly collecting in the top.
I will be putting it in the rear now, but is it ok to use if it is starting to pull away from the side?
Thanks.
Author:  GT mowog [ Thu Jul 22, 2010 8:10 am ]
Looks A-OK to me, in fact for a front pretty good. That bit of rubber that is peeling away is not where they seal, that is the big block of rubber uner that bit.
Author:  1018cc [ Thu Jul 22, 2010 8:13 am ]
Thanks GTM. So basically as the block of rubber under is it still fine, it should be ok to use until that starts to perish (if I notice it next time it is out) or until it blows?
Thanks for that, thought I would check and see if I could avoid a blow out on the road.
Author:  66S [ Thu Jul 22, 2010 8:52 am ]
Yeah, I wouldn't hesitate to use it either but you could sandblast it and urethane it together.
Al
Author:  GT mowog [ Thu Jul 22, 2010 9:07 am ]
It's not normally the rubber that would give out, it's the metalwork rusting that then causes failure of the adhesion of the rubber, or the top hose breaking off, nind you bags have been know to 'burst', fairly rare occurance though.
Author:  miniDave [ Thu Jul 22, 2010 2:02 pm ]
looks just like one that I put back in.
