It is currently Sat Jul 19, 2025 1:41 am
 Post subject: which leads to use
PostPosted: Wed Jul 21, 2010 3:59 pm
Hi,
I have the pulsar dizzy and a bosch HEC715 coil. Which ignition leads should i use? I did a search and tried the bosch B30CRi coil lead, but it doesnt fit into the coil.
Would B35Ri be ok for the other leads?
Any ideas?
Ryan
PostPosted: Wed Jul 21, 2010 6:36 pm
never had a problem with the $5 Bosch leads from supercrap...
PostPosted: Wed Jul 21, 2010 7:11 pm
yes but do you have the same coil as me?
PostPosted: Wed Jul 21, 2010 7:43 pm
Unless that coil is a funny one, just push the lead in. You can reshape the metal end bit if necessary.
I use that lead on a Bosch GT40R coil, it fitted the original Pulsar coil too.
PostPosted: Wed Jul 21, 2010 8:08 pm
Is it a transformer coil?
PostPosted: Thu Jul 22, 2010 12:33 am
well yeah that looks like it ?
reshape it, how so? it doesnt appear to go in far enough...
PostPosted: Thu Jul 22, 2010 6:23 pm
oh i got it. sorry im learning as i go, no doubt lots more noob questions to come :P
