Mini horn- Is it the same?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=64591
Author:  MG Rocket [ Fri Jul 23, 2010 8:21 pm ]
Post subject:  Mini horn- Is it the same?
This is a diagram of a Morris 1100 horn from the workshop manual.
Is the Mini horn the same?
Author:  Morris 1100 [ Fri Jul 23, 2010 8:24 pm ]
It is almost the same. The way the contact in the top of the column sits and the way the button works are different but the layout is similar.
Author:  MG Rocket [ Fri Jul 23, 2010 8:31 pm ]
Does the Mini have a spring loaded contact coming up through the middle
of the column?
Author:  Morris 1100 [ Fri Jul 23, 2010 8:35 pm ]
of the column?
Yes, but it pokes up further than the 1100 one.
Author:  MG Rocket [ Fri Jul 23, 2010 8:39 pm ]
of the column?
Ah, good. Could you give an estimation of how much further....would be just a couple of mm?
Author:  Morris 1100 [ Fri Jul 23, 2010 8:42 pm ]
From memory about 10 to 15mm further. The plunger and spring under the contact are much longer.
Author:  MG Rocket [ Fri Jul 23, 2010 8:46 pm ]
That's quite a bit.
Thanks again Morry for your usual encyclopedic knowledge.
