Minimum heater, demister for rego. NSW?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=64600
Author:  850 GT [ Sat Jul 24, 2010 2:16 pm ]
Post subject:  Minimum heater, demister for rego. NSW?
What is the minimum requirment for rego in NSW?
Dose it only have to demist or dose it have to be a heater?
It is for an 850, so what ever i use i will have to put brackets
in anyway, want to do now before car is painted etc
something like this would be good, but is local pickup only.
is anyone on here in that area :?:
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... K:MEWAX:IT
Add a fan off some sort and it could be a demister.
Thanks Scott
Author:  drmini in aust [ Sat Jul 24, 2010 2:36 pm ]
One NSW member here put a 4EFTE motor in his Clubby, for a `demister' he just used a 12V computer fan in top of dash. No heating of air at all... and it passed engineers inspection.
Author:  850 GT [ Sat Jul 24, 2010 3:00 pm ]
Would something like this do the job?
would you have to use one on each side,
or drivers side only?
http://cgi.ebay.com.au/Heater-12v-150w- ... 1c13f8a095
Author:  feralsprint [ Sat Jul 24, 2010 3:09 pm ]
If the car is pre 71 it does not require a heater at all for rego, the heater demister rule only applies to cars built after the introduction of ADRs or in the case of fitting a engine conversion.
you can buy 12v hhhhheater demister units from the kit car suppliers in the UK, just grab a copy of one of the UK kit car mags
Author:  Daren W [ Sat Jul 24, 2010 3:21 pm ]
I used a 12 volt 2 speed hair drier fitted to the demist duct from a camping store on a conversion I did years ago after all it demists the screen Daren
Author:  GoodnightWalter [ Sat Jul 24, 2010 4:49 pm ]
http://cgi.ebay.com.au/12V-Defroster-Ha ... 415167ff2b
Author:  mickmini [ Sat Jul 24, 2010 9:19 pm ]
i registered my Mini Minor for 10 years in NSW without ever having a heater or demister in it.
I only ever put a heater in when I moved to Tasmania well after I registered it. I actually needed it for demisting and heating rather than for the rego inspection :lol:
Author:  drmini in aust [ Sat Jul 24, 2010 9:24 pm ]
Back in the 60s, real men drove without a heater. Most common cars (unless top of the line versions) only got a heater as a dealer fit (or aftermarket) accessory.
My dad's FE Holden and his VF Valiant both came without one.
Demister? You bought a 12V strip heater, it sat on the bottom of the screen with rubber suction cups- they worked, too. :P
Author:  850 GT [ Sat Jul 24, 2010 9:58 pm ]
Demister? You bought a 12V strip heater, it sat on the bottom of the screen with rubber suction cups- they worked, too. :P[/quote]
My dads EK wagon is still the same to this day! the stip heater
falls off and you just stick it back on. it probably only dose 300 miles
per year, so is not realy a problem :wink:
Author:  mini_fanatic [ Sun Jul 25, 2010 8:31 am ]
there's one in my original '62 850. no idea if it still works...but the previous elderly lady owner must have needed it on the cold winter mornings we get around here....
