rear suspension https://www.ausmini.com/forums/viewtopic.php?f=2&t=64644 |
Author: | 1970cooper [ Mon Jul 26, 2010 7:15 am ] |
Post subject: | rear suspension |
I noticed my mini sitting high in the back the other day and the front was sitting on the bump stops. After reading some of the old emails on here I went to check the rear springs. Right spring is broken. Question is does the right fuel tank need to come out to get to the top nut. Thanks Felix |
Author: | GT mowog [ Mon Jul 26, 2010 7:25 am ] |
Post subject: | Re: rear suspension |
1970cooper wrote: Right spring is broken.
Question is does the right fuel tank need to come out to get to the top nut. Thanks Felix Yes. |
Author: | 1071 [ Mon Jul 26, 2010 9:19 pm ] |
Or you could cut a hole in the rear bulkhead as they sometimes did with the Works cars ![]() Cheers, Ian |
Author: | 1970cooper [ Tue Jul 27, 2010 6:29 am ] |
Thanks All, I'll see if I can move the tank out far enough to get access to the top nut. Regards felix |
