Door Hinge to Body Removal
https://www.ausmini.com/forums/viewtopic.php?f=2&t=64704
Page 1 of 2
Author:  Hanra [ Thu Jul 29, 2010 7:43 am ]
Post subject:  Door Hinge to Body Removal
Ive bitten the bullet and decided to replace the hinge to body gaskets also as Ill regret not doing it down the track.... Its been many moons since I put these on... I should of done this during the past 5 weeks that the door has been off...
What spanner size do I use and is there a trick to getting into such a tight spot?
Also is it one stud and one bolt per hinge, as it is for the hinge to door?
I used a $hit load of septone underbody sound deadner back in the day... Ive gotta get that off the threads somehow also.... hmmm....
Author:  1018cc [ Thu Jul 29, 2010 7:54 am ]
I think it is either a 7/16 or 1/2 - hopefully someone can confirm.
I have found a socket on an extension for the bottom one inside the door and one of my stubby ratcheting spanners for the others. You will also need a large phillips head screwdriver for the upper and lower ones that actually sit near the edge of the door.
Before you do anything though I would recommend buying a magnet on a stick incase you drop something into the door!
<edit> the more I think about it, the more I think they are 1/2" nuts :?
Author:  Hanra [ Thu Jul 29, 2010 8:02 am ]
Ive already got the door off, I need to get the hinges off the body however.
Author:  1018cc [ Thu Jul 29, 2010 8:15 am ]
Ah I see.
I think there is only 1 on each hinge that attach it to the body. (Last time they were off was 6 or 7 years ago so I could be wrong).
I'd use a socket on a ratchet handle to get to it :wink: I'd see if some thinners or something can soften the sound deadener before you round the nut off with brute force.
Author:  Wombat [ Thu Jul 29, 2010 8:29 am ]
1/4" bolts/screws 7/16" nuts
Author:  Hanra [ Thu Jul 29, 2010 8:33 am ]
Yeah it was 9 years ago for me... I think I read on here somewhere that its best to use a spanner with its edges ground down for more clearance or something??? I wonder if I can get my ratchet spanners in there? Not exactly looking forward to it...
Author:  Wombat [ Thu Jul 29, 2010 8:43 am ]
That is for the one up under the mudguard - the ones in the door itself are no drama except if the Phillips head screw slots are knacked
Duh! reread your post - 11mm or 7/16" ring spanner - the Z shaped ones if you have them and grind the rim thin a bit to fit between the nut and the firewall up in the top cornet under the guard - lots of swear words and bandaids on hand - WD40 helps the night before as well
Author:  Flute [ Thu Jul 29, 2010 8:45 am ]
Reading this with interest as I will need to do it as well. I read somewhere about replacing the hinge studs with stainless studs to make it easier for the future?
Ah, yes, here they are!
http://www.minispares.com/Product.aspx? ... 539&title=
Would it be worth using these?
Author:  Wombat [ Thu Jul 29, 2010 8:49 am ]
I'd say yes - but I had replaced mine before I saw those - I used antisieze on them though
Author:  Hanra [ Thu Jul 29, 2010 8:54 am ]
Z shaped you say????? Wonder if Supercrap can come to the rescue again??
Author:  Wombat [ Thu Jul 29, 2010 11:24 am ]
That's where I got mine :roll:
By Z I mean the cheapy ones that have about a 1" almost vertical bit between the handle part and the ring
Author:  Hanra [ Thu Jul 29, 2010 11:36 am ]
Sweet Ill pay them a visit again this arvy. I was glad I went there yesterday, they have some good stuff for my tool board!!!
Author:  Wombat [ Thu Jul 29, 2010 11:53 am ]
Not a good picture but like this Image
Last set I got was actually from my local Mitre10 - 1st set was Supercrap years ago - can't see them online
Author:  Hanra [ Thu Jul 29, 2010 5:45 pm ]
Nothing cheap at supercrap, actually they didnt have any individual spanners in 7/16 or 11mm....so had no choice but to go $20 Kinchrome one from Ricebarn....
Author:  Aussie Brian [ Thu Jul 29, 2010 10:08 pm ]
Okay I did mine with a 1/4" Drive socket ( can't remember the size but i am sure you will work that out easy enough ).
On the socket place a 1/4 drive universal. This gives you the angle to get away from the fire wall. Then a 6 inch extension and rachet into the universal.
Then it's happy days.
A good light to see what you are doing is also a real bonus :wink:
Brian
