It is currently Thu Aug 21, 2025 9:25 pm
PostPosted: Sun Aug 01, 2010 6:58 pm
Beware of low speed grinding/scraping noises (go away at higher speed) if you have discs. My car stopped OK but has been making these noises for a week. The S rotors both measured even thickness all over (0.345") with a micrometer.
I then found that the LH rotor had 4 cracks across the surface, 2 of them were right through the rotor and went to the outer edge.
It now has 2 new rotors on.
Brakes are important for you and everybody on the road, don't take chances.
Last edited by drmini in aust on Mon Aug 02, 2010 7:32 pm, edited 1 time in total.
PostPosted: Sun Aug 01, 2010 11:20 pm
Do you know where they came from or manufactured them? I guess that's not a failure that happens with good quality discs under normal use...
PostPosted: Sun Aug 01, 2010 11:58 pm
Tomboss Breweros
I've seen these types of cracks in rotors, and wear nearly to the point of seperating the disk from the hub. It's alarming.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Mon Aug 02, 2010 9:21 am
Now I'm worried. Bought a pair for $145.00 off fleabay some time ago as spares.
Probably made in Uzbekistan :P
PostPosted: Mon Aug 02, 2010 5:51 pm
Yes I do know, I bought them from my local brake shop, the brand is RDA (they are made in China). The other one has a few short cracks, I'll bit it too.
To be fair though, They have done a few track days using Greenstuff pads, but that was years ago. They got pretty warm back then.
Stock rotors are all only grey cast iron, I guess I was just unlucky with these ones. I've bought S rotors from Karcraft and others over the years, never had a problem.
Like I said- if you see cracks, get rid of em....
PostPosted: Mon Aug 02, 2010 10:07 pm
^^^^^^^Your just a hoon Doc :D
PostPosted: Mon Aug 02, 2010 10:09 pm
Mods rock!
Maybe, but soon he'll be eligable for the 50% discount on his rates :wink:
PostPosted: Mon Aug 02, 2010 11:14 pm
Only if I stop work, and I can't afford to. :cry:
PostPosted: Tue Aug 03, 2010 7:12 am
Mods rock!
Oh, dam that work stuff :evil: It gets in the way of life and enjoyment. Oh well at least you have somewhere to do your foreign orders.....
Users browsing this forum: No registered users and 250 guests
