It is currently Sat Aug 16, 2025 3:40 am
PostPosted: Sun Aug 01, 2010 7:18 pm
As the subject says, where abouts does the temp sender go? Also, what colour wire goes to it?
PostPosted: Sun Aug 01, 2010 9:08 pm
The temp sender connects directly to the back of your temperature gauge (if you have a early instrument cluster) with 10 volts via a regulator connecting to the other terminal on the gauge.
If you have a clubman it goes to the instrument panel plug at the back of the gauge cluster and onto the flexible PCB. Green/Blue is the colour of the roundnose wires connecting the gauge to the sender. I have no idea what colour the clubman type is.
PostPosted: Sun Aug 01, 2010 9:17 pm
Mods rock!
Same on clubbie.
PostPosted: Sun Aug 01, 2010 10:30 pm
The temp sender screws into a hole in the cylinder head below the thermostat housing, just above the engine number pad. If your cylinder head does not have this hole then the sender was fitted into a special thermostat housing made for the job. You can still buy them new, Aust castings make them, available from Bursons.
Heres a pic of an old one I use when I am painting my engines...
Have a Nice Day.
Users browsing this forum: No registered users and 359 guests
