Mini tie downs straps
https://www.ausmini.com/forums/viewtopic.php?f=2&t=64741
Author:  brett [ Fri Jul 30, 2010 10:44 pm ]
Post subject:  Mini tie downs straps
HI Guys I am chasing 4 of these, They sell them in America, UK but cant find these in Australia!
Need them before the mini muster. I have drilled tow hooks into my Cooper S but dont want to drill them into my Leyland mini.. :(
Does anyone know who sells them?
Author:  Kennomini [ Sat Jul 31, 2010 12:21 am ]
Have you got a picture?
Author:  LS1380 [ Sat Jul 31, 2010 12:38 am ]
Not sure what pic you have,but on the LS (Leyland) on the rear,drill two holes and bolt up a u/bolt on both sides of the rear subframe,then you can use chains or tie downs onto a trailer(u/bolts in red).Hope this helps.
Author:  brett [ Sat Jul 31, 2010 4:12 pm ]
http://www.realtruck.com/images/product ... _04513.jpg
Author:  DOZ [ Sat Jul 31, 2010 4:43 pm ]
I just put my ratchet strap through the subframe near the rubber cone and then go diagonally across the trailer on the rear, the front is the same but around the tie bar.
Are you worried about scratching it?
Author:  brett [ Sat Jul 31, 2010 4:49 pm ]
um yes!! :shock:
Author:  EST-071 [ Sat Jul 31, 2010 5:25 pm ]
Try these guys.
They don't have them on there site but not every thing they sell is.
Cheers Pete
http://www.fleettowing.com.au/index.htm
Author:  simon k [ Sat Jul 31, 2010 5:55 pm ]
my mate ties his mini down the way the truckies do it... big wide ratchet straps over the tyres
Author:  MiNi MuLiShA [ Sun Aug 01, 2010 12:11 am ]
Over the tyres is THE ONLY way to do it properly!
If you tie to the subrame, you will end up snapping straps n ropes, its not a bad idea as a safety measure.. just for insurance sake... but its a MUST to tie the car down with things that dont change attitude like the rims (if you have wide spokes) or over the wheels!
-Cam
Author:  willy [ Sun Aug 01, 2010 10:42 pm ]
+1 over the wheels.
Hopefully Beanie (on here) puts up images of his new setup.
Works a treat.
Tieing to subframes is rubbish - you should never tie to a sprung item - unsprung only!
