Gear Leaver
https://www.ausmini.com/forums/viewtopic.php?f=2&t=64807
Author:  Drexxle [ Tue Aug 03, 2010 12:47 pm ]
Post subject:  Gear Leaver
The gear stick on a remote change box, has the eye that the balls fits into and the ball on the end of the stick. What wears more.
I have heaps of play in this joint and the ball on the gear stick has lots of marks in it from wear. Should i replace both.
Author:  GT mowog [ Tue Aug 03, 2010 6:10 pm ]
Both, but not quite how you would expect. The alloy eye wears and the slot on the big ball of the gear lever and the pin for it also wears.
Author:  gafmo [ Tue Aug 03, 2010 9:35 pm ]
GT am I correct thier are a total of eight before the gear box of wear points
.hmm nine if you you count the Nulon Buch above the spring
Author:  Drexxle [ Wed Aug 04, 2010 9:17 am ]
8 hey
1 the half ball on the stick that goes into the remote
2 the ball on the end of the stick
3 the eye that the ball fits in
4 the hole in the end of the rod that joins the knuckle
5 the knuckle itself having two pins through it
6 the hole in the selector rod
7 the ball spring on the selector rod
and then i guess your inside the gearbox
[EDIT] I guess for a remote change box
how much play should there be around the ball in the eye. should it be a snug fit or have a few mm play.
Author:  AEG163job [ Wed Aug 04, 2010 12:31 pm ]
That's why we keep telling you guys - go remote! :lol:
