It is currently Sat Aug 16, 2025 5:39 am
 Post subject: COOPER S OIL PUMP
PostPosted: Sun Aug 01, 2010 3:24 pm
Hi,
Can you still purchase cooper s pin drive oil pumps?
I have a fresh 1380 using a morris 1300 block with standard cooper cam
http://smg.photobucket.com/albums/v515/chasg/
PostPosted: Sun Aug 01, 2010 3:42 pm
no, but various mini shops sell an adapter for spade drive pumps. You need to TIG weld it into the end for a Cooper S type camshaft
edit: pm Dr Mini, unless he pops up here
 Post subject: Re: COOPER S OIL PUMP
PostPosted: Sun Aug 01, 2010 3:46 pm
chazg wrote:
Hi,
I had a lot of dramas finding one 24 months ago, I know there are a few legacy one sitting on shelves. (I think Northern Mini Parts have one behind glass with their pretty anodised bits nad bobs). I am unsure if someone has made a new batch however. I took the option of using a slot drive camshaft (I had my pindrive converted to slot when the cam was ground) and using an easily available slot drive pump.
PostPosted: Sun Aug 01, 2010 3:55 pm
chazg,
See http://www.ausmini.com/forums/viewtopic.php?t=39787
or PM me.
PostPosted: Sun Aug 01, 2010 4:00 pm
and the great thing is, once you've done it, you can buy the Metro Turbo type high volume pump - they're good, and they're cheap
PostPosted: Sun Aug 01, 2010 4:41 pm
Std Metro 1275 slot drive pump has plenty of volume (unless you run a turbo)- my 1412 has 75psi, hot, from 1500rpm up.
PostPosted: Sun Aug 01, 2010 5:01 pm
Mods rock!
With respect guys, these were un-available for a while, but you can get them again now. All drive configuration oils pumps are available in fact.
PostPosted: Sun Aug 01, 2010 6:40 pm
Ah, but can you get the original 1100S etc spider with the spline in, I doubt it. It's been NLA for years.
I don't trust old worn oil pump drive splines, I used to own a twincam Fiat... :roll:
PostPosted: Sun Aug 01, 2010 6:54 pm
Mods rock!
Yep. I bought a (pin drive long shaft) Cooper S and spider drive oil pump (ahla 1100S spider / spline drive) Oil pumps about 3 weeks ago :wink:
And yes, they were brand new.
PostPosted: Sun Aug 01, 2010 6:59 pm
New spider? or just the pump (which have always been available)
PostPosted: Sun Aug 01, 2010 7:09 pm
Mods rock!
New pump, but while I was there I did also get a new spider :wink:
PostPosted: Sun Aug 01, 2010 7:24 pm
Minisport in SA are advertising this pump.
AEG410- Mini Cooper S oil pump (pin drive)
http://www.minisport.com.au/prod1766.htm
Not sure where it comes from?
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sun Aug 01, 2010 7:29 pm
I had a recent conversation with Andrew, I believe he has now got longer high tensile shafts made and converted these new (originally smallbore) pumps to Cooper S fitment.
Current smallbore pumps have the same rotor setup as the late lamented Cooper S AEG410 item.
PostPosted: Sun Aug 01, 2010 8:31 pm
Mods rock!
New Spider. How many did you want?
http://www.aptfast.com/Images_Parts/Eng ... s/STAR.jpg
PostPosted: Mon Aug 02, 2010 6:47 pm
Mods rock!
Going back to the original question, yes chazg, you can buy NEW pin drive Cooper S Oil Pumps, Mini Sport (SA) have them (thanks michaleb) and APT also have Sureflow ones too.
Users browsing this forum: No registered users and 323 guests
