Pipe coming from the head... what is it?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=64842
Page 1 of 2
Author:  Molina [ Wed Aug 04, 2010 11:03 pm ]
Post subject:  Pipe coming from the head... what is it?
What is the pipe that's connected to the top of the head and what is the valve that appears to be operated by a cable?
Mine doesn't have the valve, it's just got a little chrome tube on a flange that the rubber pipe is fitted over.
In this pic i can't determine where the pipe in question disappear to....
.... OHHHH... wait, is it for a heater? It just occured to me. Mine doesn't have a heater.
Anyhow... I'm planning on replacing the rubber pipe with a nice neat hard tube that hugs the rocker cover... I figure it'll look neater. There's too many rubber pipes floating around my engine bay.
Author:  gafmo [ Wed Aug 04, 2010 11:18 pm ]
it goes to the heater inside the cabin. some heater only have a switch for the fan but the valve you see lets water to pass when you want it to. Clubby Heaters have the valve down at the heater
Author:  Molina [ Wed Aug 04, 2010 11:23 pm ]
I see... I actually worked it out when i'd alread written most of the post. Thought i'd post it anyway, just to confirm.
So, do all minis have this ugly pipe and .... Wait, i think i just worked out the answer to my next question. The reason this pipe looks so ugly and pointless on my car and the car in the pics i posted are because we're both running Webers. It would have previously connected to either side of the heated SU manifold?? and thus not have to pass under the carby like it currently does. Correct? ?
Author:  gafmo [ Wed Aug 04, 2010 11:31 pm ]
if you have a heated Inlet manifold you can do that or if you dont want a heater you can also blank it off but you would also change the bottom radiator pipe also
Author:  Molina [ Wed Aug 04, 2010 11:46 pm ]
Hmmm... so i can just blank it off and put a plug in the bit of the radiator hose where the pipe would otherwise join to it.
I don't have a heated manifold so i might just remove teh pipe if that won't affect things adversely.
Author:  MiniKit [ Thu Aug 05, 2010 1:29 am ]
Oh and when you want your 1/2 inch spanner and can't find it. It's behind your brake master cylinder..
*edit to say* Just realised, that aint your car, it's Doogie's, which means it's his spanner too. :D
Author:  Convertible Mini [ Thu Aug 05, 2010 5:17 am ]
Post subject:  Lost Spanner
Hey MiniKit I was going to comment about that hiding spanner.... you beat me to it. Well spotted. I am always looking in the background of Photos too.
Author:  Bubbacluby [ Thu Aug 05, 2010 7:22 am ]
Hey mate
originally no mini in Australia came with a heated manifold.
My leyland mini and Gt's go somethinbg like what what you have got.
Author:  Wombat [ Thu Aug 05, 2010 8:41 am ]
I have one of those I'm planning to sell - get in quick and make an offer before I eBay it
Author:  Molina [ Thu Aug 05, 2010 8:55 am ]
Can't make an offer without more info. Does it go round the front or the back of the rocker cover? My Weber linkages will get in the way if it goes round the back.
Also, if i'm reading correctlyt it would appear i can get rid of the pipe completely and just blank off the hole in the head.?
Author:  norton [ Thu Aug 05, 2010 10:10 am ]
thats not a MK11 cooper S being molested is it ?
Author:  Flute [ Thu Aug 05, 2010 10:29 am ]
They look like this.
I took mine off and sold it on ebay. (The one pictured isn't mine.) It was fine but I'm trying to go back to original now.
If you don't buy it off wombat you can pay more for postage and get it here!
http://cgi.ebay.com.au/BMC-Works-Mini-C ... 5194566f30
Author:  Molina [ Thu Aug 05, 2010 11:53 am ]
I see... thanks guys.
I gave a mini specialist a call this morning and he confirmed there's no problem with just blanking off the hole in the head and running without the pipe. So, that's what i'm gonna do.
Author:  norton [ Thu Aug 05, 2010 7:19 pm ]
no heater in a car in Melbourne ??
don't forget to block the tee off the bottom radiator hose too
Author:  gafmo [ Thu Aug 05, 2010 8:16 pm ]
yep gasket, Blanking plate and change bottom Radiator Hose to a standard 1..take the heater out of the cabin
