van rotisserie https://www.ausmini.com/forums/viewtopic.php?f=2&t=64873 |
Author: | subwayseth [ Fri Aug 06, 2010 1:40 pm ] |
Post subject: | van rotisserie |
looking for the pics someone on here had of their van (maybe saloon) with an adjustable rotisserie (height wise)...can anyone help |
Author: | Kennomini [ Fri Aug 06, 2010 5:44 pm ] |
Why do you need to adjust the height? Wouldn't it be easier to just make it high enough 1st time ![]() |
Author: | subwayseth [ Sat Aug 07, 2010 11:44 am ] |
nope, going to be rolled in & out of a garden shed (low height) |
Author: | Kennomini [ Sat Aug 07, 2010 4:06 pm ] |
The simplest way would be to have the vertical pole "telescopic" with a bolt or pin through it to lock it in at the different heights, but lifting and lowering it will be the hard thing ![]() You could set it up with a trailer jockey wheel style rig on each end, raising and lowering will be eaisy but time consuming and max travel may be an issue unless you custom make it out of coarse threaded rod. |
Author: | subwayseth [ Sat Aug 07, 2010 10:35 pm ] |
think i've got a design planned out. will post some pics up when i finish. not using a full length bar so somewhat similar to the rotisseries made for late model minis just for a van instead |
