I just installed the lamps in my car. I have a relay with two switch terminals, although looking online at wiring diagrams i need two relays, one for the low beam and one for high.
Can someone help me with a basic idea of what goes where. What numbers go to what wires. Do i need two relays. I did a search for wiring diagrams but still confused.
I have already wired relay for the horn and some spotties, this headlight setup is brainstumping me.
[EDIT] also on the stalk, to dip the high beams you can push it forward, my wiring only supports this, to get it working so that when i pull back on the stalk it highbeams can i just wire it over to the other side of the base. I would like to be able to temporarily highbeam and let go and its back to lowbeam.
I am following this, but if theres an easier way, please let me know.
http://www.rowand.net/Shop/Tech/images/HeadlightRelayWiringDiagram.jpg
