fitted a weber (couple of small q's)
https://www.ausmini.com/forums/viewtopic.php?f=2&t=64894
Author:  meeni [ Sat Aug 07, 2010 1:36 pm ]
Post subject:  fitted a weber (couple of small q's)
ive just put a weber on meeni and its running 80% better then it was, im just curious as to where i can put my dissy vacuum advance tube.. and also it has a high load flat spot from low revs.. this wouldnt be because its jetted to high? it was jetted for a 1380 apparently so i may have to downsize a bit.. good noise though!
Author:  drmini in aust [ Sat Aug 07, 2010 8:28 pm ]
Nowhere to put the dizzy vac hose on a sidedraft Weber or Dellorto, forget it. It's only a (minor) economy device, that worked on near stock motors.
If running a Lucas vac dizzy, you should really put a screw through the points mounting plate into the lower one, so it can't move about with vibration.
