Seized brake adjuster
https://www.ausmini.com/forums/viewtopic.php?f=2&t=6491
Author:  ClubmanGT [ Tue Apr 19, 2005 6:38 pm ]
Post subject:  Seized brake adjuster
Does anyone know of a way to loosen (remove) a seized rear brake shoe adjuster? Mine is well seized and nothing so far has looked like moving it. If there's a 'special technique' for this I'd love to know. :cry:
Author:  13secmini [ Tue Apr 19, 2005 6:43 pm ]
have you tried to turn it from the inside with a flat head screw driver bit in a drill??
Author:  68matic [ Tue Apr 19, 2005 7:25 pm ]
because its quite large
you can squirt some WD40 in it overnight
someone recently suggested penetrating oil for these types of things too
Author:  drmini in aust [ Tue Apr 19, 2005 8:11 pm ]
Oxy torch... warm it up- works wonders on rust!
Watch you don't overheat the wheel cylinder though. :wink:
Author:  ClubmanGT [ Thu Apr 21, 2005 4:10 am ]
Thank you for the advice, unfortunately, it wasn't going to shift. In the end, I removed the back plate and used a vice. Should have done this in the first place instead of spending the best part of a day rounding the adjuster off!
Author:  J_A_M [ Thu Apr 21, 2005 8:31 am ]
aahhhhh.... 'if only'....... how many times have I been in a similar situation!!!
Glad you got it sorted. :D
