Weber Ram Tubes https://www.ausmini.com/forums/viewtopic.php?f=2&t=64915 |
Author: | jester99 [ Mon Aug 09, 2010 4:51 pm ] |
Post subject: | Weber Ram Tubes |
bought a 45DCOE weber. it has a ramflow air filter and no ram tubes. what is the best trumpet/horn/ram tube to use with a ramflow? should i get ram tubes and use filter socks? i dont have the room for the larger air filters. and no box in the firewall. any suggestions? is it worth getting ram tubes? Jason ![]() |
Author: | Monaco [ Mon Aug 09, 2010 7:42 pm ] |
I don't think Ramflows actually flow any where as well as tubes and socks or K&N element filters. I run tubes and socks but have a box in the firewall. If you have a Clubby run the Ramflow (with not too much oil in it!), if you have Roundie run some tubes and socks in behind the speedo (fireproofing is a good idea as you may get stand off). |
Author: | wild_willy [ Mon Aug 09, 2010 8:47 pm ] |
Try these. Built in stubs. http://www.hi-flow.com/HPAF1.htm |
Author: | drmini in aust [ Mon Aug 09, 2010 8:49 pm ] |
owen1975richard wrote: I don't think Ramflows actually flow any where as well as tubes and socks or K&N element filters. I run tubes and socks but have a box in the firewall.
If you have a Clubby run the Ramflow (with not too much oil in it!), if you have Roundie run some tubes and socks in behind the speedo (fireproofing is a good idea as you may get stand off). I find the Ramflo flows fine, IF you bin the stock filter foam and use a Unifilter LNX400 one instead. If you want to improve flow into the carb (and low speed mixture control) with a Ramflo on, I make 5mm radiused alloy stubstacks for this. Available in sizes 40, 42, 45mm. $55/pr including post. |
Author: | mickmini [ Tue Aug 10, 2010 1:20 am ] |
When GR ran mine on the RE engine dyno we found that there was no difference between the ramflow filter and the bare ram tubes that came with the 45DCOE. We also compared no filter, and no backplate fitted. Interestingly the plain ramflow backplate without filter or ram tubes produced the best torque and power accross the band. It was in the order of 0.5hp or so. I now run some of the drmini special stub stacks under the ramflow filter just because, although they were never tested on the dyno for comparison. So the numbers show that with my engine, there is bugger all difference. Not having to move stuff or cut the firewall with the ramflow filter for no difference in performance is the best option in my book. cheers michael |
Author: | jester99 [ Wed Aug 11, 2010 10:00 am ] |
Thanks doc, i think i might grab some of those stubstacks from you soon. also i think i will grab a unifilter LNX400 filter element aswell as the one supplied with this one is crap. i think it is some foam from something else and cut with a pair of scissors ![]() thanks for your help guys ![]() |
Author: | jester99 [ Wed Aug 11, 2010 10:08 am ] |
Doc, would you have any pics of these fitted to the carb? |
Author: | drmini in aust [ Wed Aug 11, 2010 5:29 pm ] |
Sure- Various SU ones- Weber/Dellorto ones- (filter not on) |
Author: | jester99 [ Wed Aug 11, 2010 6:14 pm ] |
thanks doc. ordered a unifilter element. also ordered $500 worth of weber parts ![]() should have everything by the end of next week. |
Author: | jester99 [ Sun Sep 05, 2010 9:29 pm ] |
Very happy with the ram tubes Doc. You have done a fantastic job machining those up. Cheers. http://www.ausmini.com/forums/viewtopic ... &start=150 |
