It is currently Mon Aug 18, 2025 8:49 pm
Post new topic Reply to topic  [ 52 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: S.U. Air Filters
PostPosted: Mon Aug 09, 2010 2:27 pm
Ive been running Ramflo filters with Finer Filter inserts for many years on my twin 1 1/4in SU's. What are the other options that are out there? Im keen to change em for something else... I like the look of the (K&N I think) Pancake style filters.
Some P/N's and pics would be a great help.
PostPosted: Mon Aug 09, 2010 2:51 pm
Give Ash some flowers Nick .
If someone doesn't beat me to it in the mean time I'll have a look for you when I get home as I run K&N pancake air filters on twin HS2's. I know they have a part number stamped into them.
When you order be sure to get the offset ones otherwise you may have clearance issues.
PostPosted: Mon Aug 09, 2010 3:16 pm
This space for rent
This is what I'm running. They're branded "HP" which I think is the initials of the guy who produces them here in Melbourne, Hans Pedersen.
http://www.hi-flow.com/HPAF2.htm
They have integral stub stacks and take a standard Ryco paper air filter element.
PostPosted: Mon Aug 09, 2010 8:12 pm
I use the Piper Cross
http://www.pipercross.net/competition/p ... _px150.asp
PostPosted: Mon Aug 09, 2010 9:29 pm
Hanra, the number stamped into the filter element itself if A059B4.
PostPosted: Mon Aug 09, 2010 9:30 pm
Tomboss Breweros
8) your engine bay is too clean, throw in some oil and dirt :lol: i like the look of the k&n stacks too.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Mon Aug 09, 2010 9:48 pm
I kinda like gafmos filter.
mooo, I'm a pig!
PostPosted: Mon Aug 09, 2010 9:51 pm
Thanks mate. So are yours K&N? Do you have a pic? Is that number off the filter housing or air filter element?
PostPosted: Mon Aug 09, 2010 9:53 pm
Mine are genuine K&N ones. I'll see if I can find a pic of them installed. There is no number on the filter housing, that number is stamped into the rubber surround that runs around the top and bottom of the filter (the bit that is hidden behind the chrome lips).
PostPosted: Mon Aug 09, 2010 10:00 pm
That's the type that I have (can't find a better shot at the moment).
PostPosted: Mon Aug 09, 2010 10:06 pm
who uses filter oil. who didnt realise that they should use filter oil.
PostPosted: Mon Aug 09, 2010 10:17 pm
Tomboss Breweros
Everyone who runs a filter that is not paper should use filter oil...
kimini wrote:
Jimmyinamini wrote:
PostPosted: Mon Aug 09, 2010 10:42 pm
Ive just realized why Ive been running this style of filter.... Its because Ive got a set of stub stacks fitted.... Im not 100% sure that they will fit inside of the K&N pancake style filter.... Id say they will foul on the filter. Dam....
PostPosted: Tue Aug 10, 2010 5:55 am
I'll measure the inside diameter of them if you like. I know my stub stacks (Dr Mini Special's) have been machined to fit inside my filters.
<edit> I just measured mine the internal Ø122mm (4.8"), external Ø146mm (5.75"), height 45mm (1.77").
PostPosted: Tue Aug 10, 2010 1:01 pm
Sweet. Thanks again. Ill have to have a gander... I dare say its not gunna fit... I think I bought my stub stacks from the US? Mini Mania possibly?
Users browsing this forum: drmini in aust and 330 guests
