Heater Hose entry (bulkhead) gasket/seal https://www.ausmini.com/forums/viewtopic.php?f=2&t=64930 |
Author: | Mearcat [ Tue Aug 10, 2010 11:33 am ] |
Post subject: | Heater Hose entry (bulkhead) gasket/seal |
I was wondering what gasket or seal for bulkhead where the heater hoses enter the cabin (and steady bar bolts to). I initially thought to use master cylinder gasket (goes under the clutch & brake masters also) but the one I removed is a foam material. Are the standard master cyl gaskets paper or a foam/rubber material? |
Author: | Drexxle [ Tue Aug 10, 2010 11:37 am ] |
i use ice cream carton to seal off the holes for the heater hoses. I removed the heater from inside the car. So these are just blocked off. I cut the ice cream carton the same shape as the gasket. |
Author: | 66S [ Tue Aug 10, 2010 11:43 am ] |
Hi Alan, The original Mk1 gaskets I've found are all a foam material, same on the heater fresh air hose blanking plate cover. Regards Al |
Author: | MiniKit [ Tue Aug 10, 2010 10:11 pm ] |
I used a foam one too Alan. If you haven't found any yet I'll rumage around my wad of parts receipts and see if I can find where I got them from.. |
Author: | GT mowog [ Wed Aug 11, 2010 7:50 am ] |
Karcraft have them P/N NAM9197. I bought one a little while ago, it was a black foam rubber. |
