help with oil rings please https://www.ausmini.com/forums/viewtopic.php?f=2&t=64956 |
Author: | tassie55 [ Wed Aug 11, 2010 6:58 pm ] |
Post subject: | help with oil rings please |
Hi just fitting new rings and am having trouble with oil ring they are 3 piece hastings ive not come across these before there is a spacer 1 ring and a 8 sided spacer i'm totally lost with how they go as the instructions on leaflet doesn't show how they fit any help appreciated |
Author: | drmini in aust [ Wed Aug 11, 2010 7:02 pm ] |
8 sided ring goes in first. Then the spacer ring Then you peel the 2 scraper rings on, working down from top of piston, 1 goes each side of the spacer ring. |
Author: | tassie55 [ Wed Aug 11, 2010 7:06 pm ] |
thanks doc thats what i thought but only one scraper ring for each piston in the box there were 4 of each spacer and 4 scrapers 12 pieces total |
Author: | GT mowog [ Wed Aug 11, 2010 7:10 pm ] |
Be sure that you don't accidentally over-lap the ends of the 8 sided ring |
Author: | drmini in aust [ Wed Aug 11, 2010 7:13 pm ] |
tassie55 wrote: thanks doc thats what i thought but only one scraper ring for each piston in the box there were 4 of each spacer and 4 scrapers 12 pieces total
sounds wrong to me, isn't there a data sheet with pics in the box? If flat chromed scrapers, there should be 8 there. |
Author: | tassie55 [ Wed Aug 11, 2010 7:21 pm ] |
youre right doc just went over to shed and checked the box and instructions on packet said 1 on top and 1 on the bottom! here's another wait for 4 more,i can't seem to take a trick latley ![]() |
Author: | tassie55 [ Thu Aug 12, 2010 7:49 pm ] |
went back into parts shop today and explained what was missing and after a few calls to mainland supplier salesman was told that it wasn't the only set with 4 oil scraper rings instead of 8 ![]() ![]() |
Author: | Convertible Mini [ Fri Aug 13, 2010 4:24 am ] |
Post subject: | Oil Rings |
Lucky you noticed and investigated it or you would have ended up with a very oily outcome. |
