BMC mini Tractor https://www.ausmini.com/forums/viewtopic.php?f=2&t=65099 |
Page 1 of 2 |
Author: | swiftden [ Tue Aug 17, 2010 9:29 pm ] |
Post subject: | BMC mini Tractor |
Hello Not mine but remember some one else talking about these a while ago and didn't they get a mention in the mini Experience Mag? http://cgi.ebay.com.au/BMC-MINI-Tractor ... yMachinery |
Author: | simon k [ Tue Aug 17, 2010 10:56 pm ] |
sweeet |
Author: | simon k [ Thu Aug 19, 2010 9:32 am ] |
I got the seller to put up some pictures of the motor... and put it in mini chat cos lots of people will never have seen the diesel A series, not that you can see much, but still |
Author: | winabbey [ Thu Aug 19, 2010 12:36 pm ] |
... and here's a Workshop Manual : http://cgi.ebay.com.au/Nuffield-BMC-Min ... erature_ET |
Author: | Mick [ Thu Aug 19, 2010 12:38 pm ] |
Imagine the engine conversion into a Mini...that would be something.. |
Author: | bnicho [ Thu Aug 19, 2010 12:45 pm ] |
Mick wrote: Imagine the engine conversion into a Mini...that would be something..
Last time I said that I was laughed at. It has somethng like 21hp. Even blown it probably wouldn't keep up with a 998 Mini. Cheers, |
Author: | Mick [ Thu Aug 19, 2010 12:47 pm ] |
Oh yeah, you would do it for stamps only.. But you could put in a 4.2 diff and use it to pull stumps out of the dirt perhaps.. |
Author: | simon k [ Thu Aug 19, 2010 4:16 pm ] |
I put up pictures a while ago of a Morris Minor panel van that has one fitted, with a little turbo on top and runs bio diesel... |
Author: | drmini in aust [ Thu Aug 19, 2010 4:59 pm ] |
bnicho wrote: Mick wrote: Imagine the engine conversion into a Mini...that would be something.. Last time I said that I was laughed at. It has somethng like 21hp. Even blown it probably wouldn't keep up with a 998 Mini. Cheers, Actually I believe it was 16HP.... less than 1/2 what a stock 850 had. The rev range is pretty limited too. [goes to consult service manual] From Nuffield Mini tractor service manual- displacement 948cc idle speed 600rpm max speed under load- 2500rpm torque 38 ft/lb @ 1750rpm C/R 23.6:1 [edit] There's no need to BUY a manual. Google BMC mini tractor, there is a link to download the manual for nix. |
Author: | GT mowog [ Thu Aug 19, 2010 5:59 pm ] |
Mmmm....that would be a waste, put it in a Moke ![]() |
Author: | MG Rocket [ Thu Aug 19, 2010 6:00 pm ] |
Is the starting bid of $9500 reasonable? And if you bought it, would you work it or turn it into a museum piece? |
Author: | Bromley [ Thu Aug 19, 2010 7:47 pm ] |
Quote: Is the starting bid of $9500 reasonable? And if you bought it, would you work it or turn it into a museum piece?
You wouldn't pay that much if you were looking for a small tractor to actually use for small farm work. |
Author: | minimanic [ Thu Aug 19, 2010 8:03 pm ] |
My parents used to have a small Leyland tractor on the farm which looked almost identical. Fantastic tractor, very versitile hard worker, used to do everything from digging to lifting motors out with the bucket. Good for getting bogged cars out of the paddock, we would somtimes lift the whole back end of the car up high in the air to push them out, mostly just to freak the drivers out..... ![]() |
Author: | sgc [ Thu Aug 19, 2010 9:13 pm ] |
Bromley wrote: Quote: Is the starting bid of $9500 reasonable? And if you bought it, would you work it or turn it into a museum piece? You wouldn't pay that much if you were looking for a small tractor to actually use for small farm work. I've been looking at little tractors like this recently.. specifically something with a back hoe. There have been a couple of early '80s Kubota 4WD backhoe/tractors recently on eBay which have fetched this kind of money. A full-size Massey Ferguson backhoe recently got no bids at $12k in two listings... If this one had a back hoe, I'd be on it like a rash ![]() |
Author: | drmini in aust [ Thu Aug 19, 2010 9:15 pm ] |
sgc wrote: Bromley wrote: Quote: Is the starting bid of $9500 reasonable? And if you bought it, would you work it or turn it into a museum piece? You wouldn't pay that much if you were looking for a small tractor to actually use for small farm work. I've been looking at little tractors like this recently.. specifically something with a back hoe. There have been a couple of early '80s Kubota 4WD backhoe/tractors recently on eBay which have fetched this kind of money. A full-size Massey Ferguson backhoe recently got no bids at $12k in two listings... If this one had a back hoe, I'd be on it like a rash :lol: You can still buy parts for Kubotas and Massey Fergusons... ![]() |
