How do the FRONT signal lenses stay in?? https://www.ausmini.com/forums/viewtopic.php?f=2&t=6527 |
Page 1 of 2 |
Author: | KiwiMR2 [ Thu Apr 21, 2005 5:24 pm ] |
Post subject: | How do the FRONT signal lenses stay in?? |
Im thinking of ordering these: ![]() How do the bits of glass actually attach to the car?? seems there is rubber bits......won't they fall out?? Cheers KiwiMR2 |
Author: | EST-071 [ Thu Apr 21, 2005 5:35 pm ] |
these ones won't fit your car as they screw on and the ones on your car fit into the rubber. Cheers Pete |
Author: | KiwiMR2 [ Thu Apr 21, 2005 5:38 pm ] |
deluxe_68 wrote: these ones won't fit your car as they screw on and the ones on your car fit into the rubber.
Cheers Pete Ahhhh...well there ya go, I would have rushed out and brought them not knowing!! Cheers for that. Well my ones that are in the rubber.....if I need to change a bulb how do they come off?? am I right in syaing the rubber is just holding them in?? Cheers KiwiMR2 |
Author: | 9YaTaH [ Thu Apr 21, 2005 6:00 pm ] |
Post subject: | Yep |
KiwiMR2 wrote: deluxe_68 wrote: these ones won't fit your car as they screw on and the ones on your car fit into the rubber. Cheers Pete Ahhhh...well there ya go, I would have rushed out and brought them not knowing!! Cheers for that. Well my ones that are in the rubber.....if I need to change a bulb how do they come off?? am I right in syaing the rubber is just holding them in?? Cheers KiwiMR2 Just carefully work a screwdriver around the rubber and get the chrome ring out....then do the sameagain for the lens... |
Author: | 68matic [ Fri Apr 22, 2005 10:34 am ] |
Quote: How do the FRONT signal lenses stay in??
dodgily. dad took one off and thought he put it back on again its just a little tight fit between a chrome ring and a rubber ring that holds it together and thats not even tight |
Author: | Harley [ Fri Apr 22, 2005 10:50 am ] |
Mine was tight. Not one day having had the car my clever dad scratched the paint with a screwdriver trying to get the in or out, can't remember. Be carefull! |
Author: | 71_mini_k [ Fri Apr 22, 2005 12:13 pm ] |
Author: | coops [ Fri Apr 22, 2005 12:25 pm ] |
HOPES AND DREAMS ![]() ![]() |
Author: | 1380 yellow devil [ Fri Apr 22, 2005 1:58 pm ] |
If the rubbers are old they will be very hard to get back in as the rubber has gone hard. I fitted a new rubber and it went back together very easy. |
Author: | 64morris [ Fri Apr 22, 2005 5:13 pm ] |
where can i get whole new front indicator assemblies? and how much? mine are crap |
Author: | coops [ Fri Apr 22, 2005 5:32 pm ] |
karcraft 1B9100<A> $46.05 LAMP - PARK LAMP+ INDICATOR ASSEMBLY Karcraft is pretty much the be all and end all get yourself a catolgue i live at coffs harbour and everthing gets here the next day and cheap freight too. ![]() |
Author: | 64morris [ Fri Apr 22, 2005 6:32 pm ] |
cool, is that for the rubber bit and the bulb holder and lense and everything? how do i get my hands on a catalogue? |
Author: | gafmo [ Fri Apr 22, 2005 11:09 pm ] |
www.karcraft.com or 9737 9944 working days only ![]() Also availiable on disc |
Author: | drmini in aust [ Sat Apr 23, 2005 7:20 am ] |
gafmo wrote: www.karcraft.com
or 9737 9944 working days only ![]() Also availiable on disc U left the `.au' off... It's www.karcraft.com.au or email [email protected] ![]() |
Author: | KiwiMR2 [ Tue Apr 26, 2005 7:10 pm ] |
Cheers Pete Hey how can you tell from the pic it only fits screw on ones?? I saw a MK4 in the weekend JUST LIKE MINE with the silver ring and rubber BUT with clear indicator glass like the ones above. Cheers KiwiMR2 |
