90 Degree speedo linkage.......
https://www.ausmini.com/forums/viewtopic.php?f=2&t=6528
Author:  sg [ Thu Apr 21, 2005 5:38 pm ]
Post subject:  90 Degree speedo linkage.......
Probably has never been made or developed, but i'm stabbing in the dark here.......
Does anyone know if there has been a angled coupling that screws on the back of the speedo to enable the cable to run off to either side instead of straight out the back of the guage?????
Sorry if my stupidity offends anyone..... :oops:
Author:  miniron [ Fri Apr 22, 2005 4:13 pm ]
:D
Yes!!!
Made by Smiths. Part No BG 2410/004. Essential if you run a centre speedo and a Weber with a decent aircleaner.
Probably be able to get one from your local speedo man.
Regards
RonR
Author:  sg [ Fri Apr 22, 2005 4:19 pm ]
Ron i love your work........... cheers
Still coming up for muster????
Steve
Author:  Chris [ Fri Apr 22, 2005 5:42 pm ]
Post subject:  Re: 90 Degree speedo linkage.......
If you cannot locate the one Ron mentioned they were fitted to various overdrives. I had several Triumphs and they all had angle drives on the OD. Any Triumph dealer would be able to supply. I am not sure if they were 1:1 through the drive, if not you may need to calibrate the speedo. TR Spares in Sydney would have one I would think.
Author:  sg [ Fri Apr 22, 2005 6:19 pm ]
Cheers Chris.... will check that also :wink:
Author:  justminis [ Fri Apr 22, 2005 6:46 pm ]
Range Rovers too, 1:1 right angle speedo drive.
Author:  Chris [ Sun Apr 24, 2005 10:40 pm ]
Here you go....
http://www.trademe.co.nz/Trade-Me-Motor ... 916830.htm
Author:  sg [ Sun Apr 24, 2005 11:34 pm ]
Chris cheers for that.... now i know what i am looking for. Will be hunting one of those down this week :wink:
