Clutch Master Cylinder Piston getting stuck!
https://www.ausmini.com/forums/viewtopic.php?f=2&t=65325
Page 1 of 2
Author:  MiniMe87 [ Sun Aug 29, 2010 1:09 pm ]
Post subject:  Clutch Master Cylinder Piston getting stuck!
Hey everyone,
Just tried connect up my clutch and the piston keeps seizing at the top of the clutch master cylinder....its not getting sucked back down when the pedle goes down....i have tried soaking the piston (from top and bottom) with brake fluid but it keeps happening!!!
any ideas????
Author:  Mick [ Sun Aug 29, 2010 1:19 pm ]
Has the master cylinder been apart?
Was the return spring inside the MC replaced when it was reassembled?
Author:  Drexxle [ Sun Aug 29, 2010 1:49 pm ]
how long was it on the shelf. surface rust in the bore and the rubber is getting caught on it. take the thing apart, use some steel wool to give the bore a LIGHT clean.
as mentioned if the spring is worn replace it. might need to replace the rubber too.
Author:  MiniMe87 [ Mon Aug 30, 2010 2:08 pm ]
how exactly do i take it apart?? from memory i cant remember actually seeing any bolts or anything that i could undo to get to the piston inside the clutch master cylinder??
Author:  Mick [ Mon Aug 30, 2010 2:10 pm ]
There's a circlip inside the bore which will release the contents of the master cylinder.
Author:  MiniMe87 [ Mon Aug 30, 2010 2:16 pm ]
how do i get to that circlip?? is it near where the bar that pushes the piston, which connects to the clutch pedal is?
Author:  Lillee [ Mon Aug 30, 2010 2:27 pm ]
Take MC off car, emty it, turn it upsidedown, look down the mc pushrod (shaft that pushes pedal pushes into the MC), there will be a rubber boot over the top of the end of the MC where the shaft goes in. Remove the boot, it has an inner ring that slides up and down the shaft. Inside of where that boot was around the inside of the MC where the shaft goes in is where the circlip is. You need good needle nose pliers or circlip pliers to get it out. Then the whole thing will come apart.
If you've gotten this far then buy the correct MC repair kit which will have new rubbers etc and redo the whole thing. Be wary which way the parts come out, particularly which way the rubber plunger seal inside the piston itself goes.
Good luck!
Author:  Mick [ Mon Aug 30, 2010 2:27 pm ]
Yeah, you will need to take the pin out which connects the master cylinder pushrod to the pedal, and then unbolt the mastercylinder from the car from inside the engine bay.
Author:  MiniMe87 [ Mon Aug 30, 2010 2:46 pm ]
wow this sounds .................nice and easy!
Ill give it a shot....i cant stuff it anymore then it is now i guess/hope :lol:
Author:  Lillee [ Mon Aug 30, 2010 7:15 pm ]
Nar it's really easy, harder than it sounds. Describing it is far harder than doing it!
Author:  DartzMan [ Sun Sep 12, 2010 5:49 pm ]
Post subject:  Master Cylinder
Sorry to jumpin on the thread.. I started to pull my tin pots apart so I can overhaul them,.,.... Managed to remove the dust cover, the C ring and then remove the plunger... however the dished Stopwasher seems to be stuck in the units.... have sprayed with Lubricant and tapped the bottom of the unit on a lump of wood however it wont budge... either there aint one in there or it is jamned or I am missing something....
Any Ideas?
Kevin
Author:  mini_mad_matt [ Sun Sep 12, 2010 6:28 pm ]
So it sounds like you removed the pushrod but the piston is still stuck yea? Try sealing the holes with a rag as you blow compressed air into the top of the cylinder. Make sure you have drained all the fluid out though, or you might just spray it everywhere, and wrap a rag around the cylinder so when the piston shoots out the rag catches it.
Author:  DartzMan [ Sun Sep 12, 2010 6:36 pm ]
Post subject:  stuck
cheers mate, will give that a go, just annoying, both are stuck
Kevin
Author:  Drexxle [ Sun Sep 12, 2010 6:37 pm ]
if you havent got an air compressor a thin bit of wire and try and poke it out from the top.
Author:  DartzMan [ Tue Sep 14, 2010 7:36 pm ]
Post subject:  Cylinder
Tried the Compressor, didnt work, sprayed the unit all over with Inox..(like WD40 but better), came out a treat... Bore and piston look good.. Will look at putting a refurb kit in,... Where can I grab those from?
