It is currently Wed Jul 23, 2025 7:04 pm
 Post subject: Weber Fuel leak question
PostPosted: Fri Sep 03, 2010 8:42 pm
Hi everyone,
yesterday when i went to drive to work early in the morning, my engine developed a miss as soon as i started to drive. i had warmed the engine at idle for a minute or two before setting off.
i thought it may have been related to being cold or something similar. after a 5 km drive no change. no choke was used.
i pulled over and pulled the plugs and found cylinders 1 & 2 were very wet with fuel. there was spark at both cylinders, but both were not firing. i removed the leads while the engine was idling and cylinders 1 & 2 had no change to the missing, indicating those cylinders were the cylinders missing.
i drove the car home and let is sit there until this evening so i could have a look at it. so tonight i started it and had the same issue.
so i removed the carb, pulled it all down cleaned it all out, and re-fitted it, cleaned the plugs, and now it idles and fires on all cylinders again.
what i think happend was while the engine was sitting parked overnight before i had the missing issue, fuel had leaked from the carb into cylinders 1 & 2 and caused the spark plugs to foul the morning i drove it.
what would be causing this to happen? fuel leakage into the cylinders while the engine is turned off overnight.
any ideas? leaking pump jets?
thanks in advance
Jason 8)
PostPosted: Fri Sep 03, 2010 9:13 pm
Maybe float level is set too high? or perhaps there's too much fuel pressure.
 Post subject: Weber
PostPosted: Sat Sep 04, 2010 7:32 am
Also make sure the Carb is sitting at the correct angle as that will effect float level too.
"Let us remove your "SHORTS"
Users browsing this forum: No registered users and 128 guests
