It is currently Sat Jul 19, 2025 7:23 pm
 Post subject: different radiators??
PostPosted: Sat Sep 04, 2010 3:58 pm
i was putting the radiator in my 63 when i seemed to run out of room,the bracket from the thermostat housing is about 1 inch away from where it should be, is there different radiators or brackets?? or have i done something wrong
Darren
00 triton d/cab
55 chev(oversize moneybox)
1963 850 (roundie)
77 clubby
95 zxr 750 + toys!!
PostPosted: Sat Sep 04, 2010 9:04 pm
There's at least 3 common styles of top bracket, at least two of the lower angled one, two different early shrouds and two lower engine mount brackets. But most of the common radiators use the same mounting points.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Sun Sep 05, 2010 8:03 am
thanks tim was going through another box of bits last night and found shorter top bracket now just have to look for different bottom one as the 2 bolts hit the balancer
Darren
00 triton d/cab
1963 850 (roundie)
77 clubby
95 zxr 750 + toys!!
Users browsing this forum: No registered users and 64 guests
