It is currently Mon Jul 21, 2025 3:51 pm
 Post subject: Gearbox stampings
PostPosted: Mon Aug 30, 2010 11:24 pm
To those in the know,
Is there a significance that can be taken from the stampings on a gearbox case (not the casting numbers). There is a little flat area on the drivers side front of the 4 synchro gearbox which can be stamped (but not always).
The box I have (An 1128 4 synchro box)is stamped: 5/2781/2
Does it mean anything to anyone ?
Mick
 Post subject: Re: Gearbox stampings
PostPosted: Tue Aug 31, 2010 3:15 pm
Mick
hmmmm ... doesn't sound like it mick..... :lol:
PostPosted: Tue Aug 31, 2010 4:31 pm
wow, where are all the rivet counters when you need them :(
Not to worry, I'm sure one will be along in a short while...
PostPosted: Tue Aug 31, 2010 4:47 pm
My 4 synchro Cooper S box is marked F/XE 1215. All my other spare boxes are also stamped with numbers. I would think that they are serial numbers. with F denoting Cooper (as in the engine number 9F) and XE being close ratio. Another 4 synchro is stamped 22/7365. From an 022 Clubman??? - just guessing??? 997 Cooper box stamped 9F16536
Others?
PostPosted: Tue Aug 31, 2010 4:52 pm
Mods rock!
I'm reasonable sure that the Cooper S and Clubman GT Gearboxes were stamped there, but the Mini K, even though it was the same case, was not stamped.
I've never bothered to keep track of what has been stamped on them so I cannot shed any light on their meaning.
PostPosted: Tue Aug 31, 2010 5:42 pm
I've often wondered about that stamped number myself.
I have 3 22G1128 boxes here :
One has nothing, I think I was a mini K box
22\1374 - Came from an early clubman, still had hydro & remote
21/3507 - unknown origin, no visible differences to the other 2
Jacob
PostPosted: Tue Aug 31, 2010 9:15 pm
Not sure, but the info I was given was as follows:
the stamped number was to indicate the gearset used
FAXE followed by numbers denotes Cooper S gear set however these were not always stamped.
Maybe this sheds some light
PostPosted: Tue Aug 31, 2010 9:32 pm
Mods rock!
Just done a little poking around on this. According to factory info every gearbox fitted to a car was stamped and this was the gearbox serial number. It would also appear (it's a bit criptic) that some (?) did have a prefix to denote special features, like remote shift, close ratio gears etc.
No leads just yet on the list of prefixes and what they mean.
I know I've seen quite a few with nothing stamped on them.
PostPosted: Tue Aug 31, 2010 9:49 pm
:lol: :lol: :lol:
LOVE IT
PostPosted: Tue Aug 31, 2010 10:39 pm
From memory, the Mini Kingdom parts book has a list of these numbers.
Have a Nice Day.
PostPosted: Wed Sep 01, 2010 12:18 pm
I've seen the type of marking Wild willy is describing, 9F.... F.XE etc. but also S and Cooper boxes with all correct gears, but no marking at all!
John Schmidt might be a good port of call! 8)
Sir Alec! we are not worthy!
PostPosted: Wed Sep 01, 2010 7:13 pm
Replacement cases were not stamped. :wink:
PostPosted: Mon Sep 06, 2010 8:33 pm
I just noticed in a couple of Mini factory parts manuals that this is called the Transmission Assembly Number.
