It is currently Fri Jul 25, 2025 10:23 pm
 Post subject: Battery box replacement
PostPosted: Thu Sep 16, 2010 10:50 am
Hi everyone!
This is more a question for all the welders and panel beaters out there! im about to replace my battery box. I was just wondering how everyone else has done theirs? is it ok to just mig weld it in? I understand they were orgionally spot welded and brazed on the corners? I dont have the gear to do this however... Is there any sealant to ensure it doesnt rust out again that i should be using aswell?
this will be my first time welding, so i just want to make sure i do it right!
Thanks everyone!
PostPosted: Thu Sep 16, 2010 10:57 am
Most people drill holes through the flange then plug weld with the MIG.
Mine was only rotted in the bottom, so I cut all the base out except for a 4mm flange around the edge. Then I cut a piece of 2mm plate, dropped it inside and MIG welded it.
A bit or rubber underseal paint and it looks like a bought one again.
 Post subject: battery Box
PostPosted: Thu Sep 16, 2010 1:12 pm
Cut mine out and fabricated New one.. will be welded in.. Mini restore book says Rivet new one in.. not sure about that though....
MY MINI
Morris Mini Deluxe 1967 Restore - 100% BMW FREE
http://www.berdenweb.com/mymini
PostPosted: Thu Sep 16, 2010 5:11 pm
I riveted one in - plenty of Silaflex around the lip and a coat of tar inside and out then colour paint to suit the rest of the car.
David L
PostPosted: Thu Sep 16, 2010 5:58 pm
can you buy this as a part, or do they have to be made up, i cracked mine on the bottom from being off road. I should replace it.
PostPosted: Thu Sep 16, 2010 6:10 pm
I replaced mine last week. Cut the old one out with an angle grinder, bought a new battery box, beat the absolute crap out of it because it was the wrong shape, then beat it into something closer, sandblasted and epoxy primed it followed by stone guard / sound deadener, then welded it into the top by plugging holes with a mig.
I hasn't welded anything in about 8 years before that. Now I want to weld something else.
:lol:
 Post subject: battery box
PostPosted: Thu Sep 16, 2010 8:34 pm
http://www.minisport.com.au/prod36.htm
You can find a replacement at the link above
MY MINI
PostPosted: Thu Sep 16, 2010 10:25 pm
if i was to do mine again i would just cut the bottom off (thats where it mainly rusts) and just make up a piece outta metal i have lying around. the the prefab ones arent always a perfect fit.
PostPosted: Fri Sep 17, 2010 7:33 am
Mods rock!
....and they seem to be of a guage steel about half that of the original.
 Post subject: Bat Box
PostPosted: Fri Sep 17, 2010 7:38 am
made mine out of 1.2.. seems alot heavier than the rusty one I cut out... could have gone with 1.00 but at least this way the car wil rust out before the Batt Box..
Might look at rivetting in.be easier if I ever need to remove
MY MINI
