Powder Coat Tin Pots https://www.ausmini.com/forums/viewtopic.php?f=2&t=65662 |
Author: | DartzMan [ Tue Sep 14, 2010 8:07 pm ] |
Post subject: | Powder Coat Tin Pots |
Has anybody powdercoat Brake and Clutch tin pots? Did they come out alright? Also wheres the best place to pick up refurb kits Kevin |
Author: | Morris 1100 [ Tue Sep 14, 2010 8:12 pm ] |
I bet someone has done it but it is not a good idea. The heat from the oven can warp the cylinder or melt the solder on the tank. |
Author: | DartzMan [ Tue Sep 14, 2010 8:23 pm ] |
Post subject: | tin Pots |
after looking at the pots, condition etc , I may opt for the plastic replacements....The bore looks ok but cant guarantee..I will need a refurb kit.. the outside is crap , end of the day I think new plastic ones may be a tad more reliable thanks all the same |
Author: | Lillee [ Tue Sep 14, 2010 9:57 pm ] |
You can buy brand new tin ones if looking for that original look. IMO the plastic ones are better as you can see when they are empty ![]() |
Author: | michaelb [ Tue Sep 14, 2010 10:10 pm ] |
You can also have your tin one refurbished. Some brake shops will replate the tin can and fit a stainless sleeve into the bore and then it will look like new. |
