bad lean https://www.ausmini.com/forums/viewtopic.php?f=2&t=6567 |
Author: | meeni [ Sat Apr 23, 2005 2:38 pm ] |
Post subject: | bad lean |
my car is sitting way to high on the passenger side, the camber is bad because of this is there a way to fix this problem without spending much money?? |
Author: | 9YaTaH [ Sat Apr 23, 2005 2:54 pm ] |
Post subject: | Re: bad lean |
meeni wrote: my car is sitting way to high on the passenger side, the camber is bad because of this is there a way to fix this problem without spending much money??
Is it a Hydrolastic or rubber cone suspension type vehicle ![]() If hydro...then you can just pump up the side thats ...well...down ![]() |
Author: | meeni [ Sat Apr 23, 2005 3:28 pm ] |
na its rubber cone, i have barley any money to spend on it, only 50 bucks richer at the moment, anything i can do? |
Author: | Rupert [ Sat Apr 23, 2005 4:10 pm ] |
It will most probably be one or both knuckle joints. $15 each but you'll need a rubber donut compressor. |
Author: | drmini in aust [ Sat Apr 23, 2005 5:09 pm ] |
Rupert wrote: It will most probably be one or both knuckle joints. $15 each but you'll need a rubber donut compressor.
...and hope that there are still threads inside the donut for the puller to screw into.. ![]() |
