How Fast? https://www.ausmini.com/forums/viewtopic.php?f=2&t=65710 |
Page 1 of 4 |
Author: | 64mini [ Fri Sep 17, 2010 1:02 pm ] |
Post subject: | How Fast? |
I was wondering what is the best engine for maximum speed? |
Author: | Mick [ Fri Sep 17, 2010 1:06 pm ] |
I think Malcolm Campbell proved a big **** jet turbine was the go. Maybe 25000 shaft horse power would do it, maybe a GE LM2500 then. But whats the context? |
Author: | 64mini [ Fri Sep 17, 2010 1:07 pm ] |
Mick wrote: I think Malcolm Campbell proved a big fiddle sticks-off jet turbine was the go. Maybe 25000 shaft horse power would do it, maybe a GE LM2500 then.
for a roundie dumbo - do you think that makes a difference given that they are more aerodynamic than those bluff fronted ones? |
Author: | Mick [ Fri Sep 17, 2010 1:13 pm ] |
Must be some drag coefficient calculations out there somewhere... ![]() Beyond that, I suppose there's no substitute for cubic inches. |
Author: | drmini in aust [ Fri Sep 17, 2010 1:15 pm ] |
64mini wrote: for a roundie dumbo - do you think that makes a difference given that they are more aerodynamic than those bluff fronted ones? There's not much difference in drag between a roundy and the `Ford fronted' ones. They are both pretty poor CV, but better than a Moke (with or without the tent erected). ![]() |
Author: | marc2131 [ Fri Sep 17, 2010 1:27 pm ] |
Post subject: | Re: How Fast? |
64mini wrote: I was wondering what is the best engine for maximum speed?
I would think a Mk 1 or Mk 2 1275 engine. I did read as a bog standard item they'd reach 100mph or just under. |
Author: | 64mini [ Fri Sep 17, 2010 1:33 pm ] |
marc2131 wrote: 64mini wrote: I was wondering what is the best engine for maximum speed? I would think a Mk 1 or Mk 2 1275 engine. I did read as a bog standard item they'd reach 100mph or just under. but not all 1275 are created equal. Would a tuned 1100 beat a boggo 1275? |
Author: | Maxi23 [ Fri Sep 17, 2010 1:42 pm ] |
I feel that a supercharged 1098 would beat a stock standard 1275, but thats assuming the block has in fact been painted red to make it go faster. |
Author: | 64mini [ Fri Sep 17, 2010 1:48 pm ] |
Maxi23 wrote: I feel that a supercharged 1098 would beat a stock standard 1275.
What do you base that on? Wouldnt a blown 998 be better than an 1100? |
Author: | norton [ Fri Sep 17, 2010 2:14 pm ] |
I had my std cooper s upto 115 mph once, ![]() ![]() |
Author: | 64mini [ Fri Sep 17, 2010 2:14 pm ] |
norton wrote: I had my std cooper s upto 115 mph once,
![]() ![]() must have been a big cliff |
Author: | Drexxle [ Fri Sep 17, 2010 2:28 pm ] |
you could blow all four piston rings like i did taking the speedo off the dial, bouncy bouncy i dont want to go any further, the needle said to the car. |
Author: | Drewie [ Fri Sep 17, 2010 2:47 pm ] |
A couple of little stories from the 70's. I was in the National Service at the time, I had a 997 Cooper that I had modified quite a bit, it had an 1100cc block with a worked head, Wade 140 cam, weber and a few other bits, I thought it was very quick until another Nasho said come for a ride in my 1275 Cooper S, it was brand new, about a month old, at the time I could not beleive how quick it was, I was shell shocked, within 2 weeks I had traded the Cooper on a new Cooper S. The fact it was a brand new car I think made a big difference it was so much faster than my 1100. That same car was a very very good example we compared it to my then new S and his was always that little bit better all round in performance. As to top speed, back before the hume freeway was built in Victoria there was a big hill called 'Pretty Sally' near Seymour, we had 4 Nasho's on board the S and he wound it off the clock going down this long long hill, I remember the needle wound right past the 120mph mark, it was down hill though. His was a very good stock S though and he could readily pull 100 even on a flat ground but there was nothing much left in it. By the way there were no speed limits then! |
Author: | drmini in aust [ Fri Sep 17, 2010 2:52 pm ] |
Back in 1969 (no fixed open road limit in NSW then) a Mk2 Police Cooper S was good for 106MPH, downhill. So said Mr Plod when I slowed down for a town, and he finally caught up. ![]() |
Author: | 64mini [ Fri Sep 17, 2010 2:53 pm ] |
My problem is by the time you have hit 100mph you have done half a lap of the island. |
Page 1 of 4 | All times are UTC + 10 hours |
