ignition barrel HELLLLPPPPP https://www.ausmini.com/forums/viewtopic.php?f=2&t=6579 |
Author: | benjamin [ Sat Apr 23, 2005 9:45 pm ] |
Post subject: | ignition barrel HELLLLPPPPP |
i won a ignition barrel on ebay as mine is broke http://cgi.ebay.com.au/ws/eBayISAPI.dll ... 4543613690 how do i take the one off my car the screws are just flat on the top, do i just drill em out? and where eould i get new ones from or is there a special way to get them out ![]() hellllllp |
Author: | WhoDat [ Sat Apr 23, 2005 9:55 pm ] |
Drill small diameter holes down the middle of the shear bolts and then use "easy-outs" or similar. replace with normal fasteners when re-building. |
Author: | aaron [ Sat Apr 23, 2005 9:59 pm ] |
Drill em out or if your impatient Angle grinder with a cutting disc. When you get it, take it to a bolt place and pick up two with the right length and thread. Easy Cheers Aaron |
Author: | benjamin [ Sat Apr 23, 2005 10:02 pm ] |
so you cant get the same bolts again or get the same sort? cant someone steal the car if i use normal bolts? |
Author: | aaron [ Sat Apr 23, 2005 10:05 pm ] |
If your worried about someone stealing your car, you should be worried as mini's are so easy to break into and start. If your worried about that kind of thing, put a cut out switch in with a removable toggle. Cheers Aaron |
Author: | benjamin [ Sat Apr 23, 2005 10:08 pm ] |
naa im not worried just wondering if you can get the original bolts |
Author: | Chris [ Sat Apr 23, 2005 10:10 pm ] |
aaron wrote: Drill em out or if your impatient Angle grinder with a cutting disc. When you get it, take it to a bolt place and pick up two with the right length and thread. Easy
Cheers Aaron Get two ordinary bolts and neck them down in a lathe the same as the originals. Use a centre punch to get them out, at least that is what I have done in the past with no problems. |
Author: | aaron [ Sat Apr 23, 2005 10:10 pm ] |
Doubtful, but you can try. Bolt specialsts are your only hope really. Cheers Aaron |
Author: | Morris 1100 [ Sat Apr 23, 2005 10:12 pm ] |
If you are good you can undo them with a hammer and a punch. If you have a Dremmel you can cut a slot in them and use a screwdriver. If you cut a slot in them you can fill the slot with araldite after you do them up again. Only you will know what is under the araldite. |
Author: | min13k [ Sun Apr 24, 2005 1:52 am ] |
i have a steering collum with the barrle and key intact so all ya gotta do is change the collum 50 and it is yours makka |
Author: | benjamin [ Sun Apr 24, 2005 10:14 am ] |
mmmm, ill keep it in mind if this becomes too hard thanks for the offer |
Author: | benjamin [ Mon Apr 25, 2005 11:44 am ] |
ok i got it all in but when i turn it to start nothing happens. ok befor i put it in i had a button that i pressed so i unwired all that and wired the ignition barrel back in when you turn the key the dash lights come on but it wont start any ideas?? there was a wire in the engine bay infront of the starter motor that used to go to the button and back to that thng with the fat wire going to it next to the head and engine steady, i touch the wire on the front of this and the starter motor tured hellllp how do i fix ![]() ![]() |
Author: | benjamin [ Mon Apr 25, 2005 4:55 pm ] |
heres a pic, the thing above the coil what wires are meant to go on the things circled ![]() |
