It is currently Sun Aug 17, 2025 7:48 am
 Post subject: Leyland Mini
PostPosted: Wed Sep 22, 2010 10:17 am
Did the Leyland Mini have a YG2S3 body number? What size is a motor with 1200 stamped on it, as i have seen engine sizes 1100 and 1275?
PostPosted: Wed Sep 22, 2010 11:05 am
Mods rock!
The YG2S3 Body Prefix is the 'base model' Mini 1100 (similar to Mini K but lower spec). Generally these were sold to the likes of the post office, GD Police Cars, and Utility Companies. It would be likely that some were also sold to the general public.
The 1200 engine prefix is unique to the Australian Clubman GT. These were either same as MKII Cooper S Motor (exactly except for the engine prefix no.) or where based on the 1100s type Block (no tappet covers) but with Cooper S Crank, Cam, Rods, Pistons, Cylinder Head etc.
PostPosted: Wed Sep 22, 2010 2:11 pm
and Export Moke (1206 I believe)
PostPosted: Wed Sep 22, 2010 3:10 pm
Did the Mini 1100 have disc brakes and booster, twin carbs and 2 fuel tanks?
PostPosted: Wed Sep 22, 2010 3:26 pm
Are you sure it is not YG2S 8?
If so, you may have a GT.... 8)
PostPosted: Wed Sep 22, 2010 3:42 pm
drum fronts, no booster and single HS2 carby, some cars may have had a twin tank put in as an aftermarket accessory.
PostPosted: Wed Sep 22, 2010 3:48 pm
Mods rock!
Drexxle wrote:
....... some cars may have had a twin tank put in as an aftermarket accessory.
The right hand tank was available as an option up to about 1971 or so.
PostPosted: Wed Sep 22, 2010 3:52 pm
Going to have a look today, ad says YG2S3.
The photo is square body is that correct?
PostPosted: Wed Sep 22, 2010 3:53 pm
Mods rock!
Should be what is commonly refered to as a roundie.
PostPosted: Wed Sep 22, 2010 4:23 pm
jeez.... all the evidence is pointing to the owner reading an 8 as a 3...
PostPosted: Wed Sep 22, 2010 4:48 pm
Mods rock!
A real possibility......................
PostPosted: Wed Sep 22, 2010 5:27 pm
Hey Kaka
I know the one you are talking about. Red with Gt stripes, i know there were pictures on either the GT site when it was running or on Gavins Gt register. I cant remember which one and i cant remember whether it was a genuine GT or not.
But for it to have twin carbs, a 1200 motor and fuel breather under the seat, as well as the condition of it from the ad looks incredible for 3500 is very cheap. I paid that for one that needed rust removal and was last regoed about 20yrs ago. So bargain.
make sure you keep us informed.
Just check behind the master cylinders in the driverside should read
m2
23
XXX
Brenton
PostPosted: Wed Sep 22, 2010 5:54 pm
http://brisbane.gumtree.com.au/f-leylan ... hFormZtrue
This is it. Will give more details after the weekend, when it delivered.
Thanks guys for your help.
PostPosted: Wed Sep 22, 2010 6:00 pm
Yeah i did a quick search and found the one you have mentione. Did you have a look at it before you said yeah?
Your link doesnt work it should be:
http://brisbane.gumtree.com.au/c-Cars-V ... Z231408222
PostPosted: Wed Sep 22, 2010 6:04 pm
If you don't want the wheels please let me know. :D
Users browsing this forum: No registered users and 389 guests
