brakes https://www.ausmini.com/forums/viewtopic.php?f=2&t=65961 |
Author: | i got a mini [ Mon Sep 27, 2010 10:04 pm ] |
Post subject: | brakes |
ok guys just to clear this up i have standard wheel cylinders on the back of my brakes and i got 7.5 disk brakes on the front reco master cylinder do i have to put the smaller wheel cylinders on the back to get better brakes or i should have good brakes dont matter which size i run at the back |
Author: | drmini in aust [ Mon Sep 27, 2010 10:26 pm ] |
In my experience, it will lock the backs up under heavy braking. This is bloody dangerous in wet weather on a freeway,as I found out on the F3... ![]() If I'm fitting ANY front discs I'd fit new 5/8 rear wheel cyls at the same time. ![]() |
Author: | mini_mad_matt [ Mon Sep 27, 2010 10:29 pm ] |
The brake pedal should develop pressure with less travel with 5/8th on the back (making it "feel" better). And as drmini suggested it can be dangerous without the right size as i found out as well. |
Author: | i got a mini [ Mon Sep 27, 2010 10:46 pm ] |
i have no boster if this changes anything |
Author: | miniobsessed [ Mon Sep 27, 2010 11:24 pm ] |
i got a mini wrote: i have no boster if this changes anything
Nope... Just means you don't have to push the pedal as hard for the same braking effort. |
Author: | Lillee [ Mon Sep 27, 2010 11:31 pm ] |
It matters which is at the back! S brakes need S rear cylinders as per Doc's post. If not, 360 or 720 under hard braking... |
Author: | ryan [ Tue Sep 28, 2010 10:07 am ] |
When I first got my car, I had a different sized cylinder on each side ![]() ![]() As the others say, you need the smaller size. |
Author: | gafmo [ Tue Sep 28, 2010 8:03 pm ] |
Also don't forget to adjust your rear brakes |
