It is currently Sun Jul 20, 2025 11:35 pm
PostPosted: Sat Oct 02, 2010 7:57 pm
Where and how much?
 Post subject: Belt up
PostPosted: Sat Oct 02, 2010 10:17 pm
I know that http://www.minisport.com.au/category59_1.htm
has some.
Also ebay has a few but remember to get the plates as well.
Also http://www.minispares.com sells belts
Manda
Madam Cheglair - 1970 Mini K
PostPosted: Sat Oct 02, 2010 10:21 pm
Cush, child seat mounts are entirely different thread and bolt size to seat belt anchorage plates that minisport sells so be wary of that. Otherwise those minisport plates are well worth the money.
Minisplus sells Klippan non-intertia lap sash belts for the cheapest I've seen.
You will still need to make a plate with 2 bolts welded to it for the buckles in the middle of the seat much like in a clubman
MSG me for more info
PostPosted: Sat Oct 02, 2010 10:43 pm
You mean `2x 7/16" UNF NUTS' mate..
:wink:
PostPosted: Sat Oct 02, 2010 11:39 pm
I imagine Image are for mounting the seatbelt to the parcel shelf. Can't they be used down the bottom? I'd need 6 of them, wouldn't I?
 Post subject: seat belt hole!
PostPosted: Sun Oct 03, 2010 7:58 am
i used the top bolt where the seat belt mounts!
 Post subject: Re: seat belt hole!
PostPosted: Sun Oct 03, 2010 8:23 am
Ben, early cars do not have the factory seat belt mounts in the rear like Clubby's do. My 6/70 K doesn't have them but my 12/70 K does, so were added by the factory around that time.
Steve
PostPosted: Sun Oct 03, 2010 8:44 am
OH yeah... we're talking 1964 here, so it's all solid back there. :)
PostPosted: Mon Oct 04, 2010 12:29 am
Michael, I suggest going and seeing Stuart @ Willshire Motor Trimmers.
I believe the image Minisport SA have used is the exact seatbelt plate (T51 WMT part number; 7/16" UNF thread), that WMT sell.
You'll also need the 5/16" UNF child anchor point plates too - I'm pretty sure the part number for these is T52 but Stuwey will sort you out.
Don't muck around with this stuff!
See the people that do the fitting every day :wink:
PS they certainly aren't almost $8.00 at WMT.
At least I am useful for something.
PostPosted: Mon Oct 04, 2010 1:01 am
I can think of some uses for you...
