Main wheel hub bolt torque settings https://www.ausmini.com/forums/viewtopic.php?f=2&t=66093 |
Author: | MiniMe87 [ Mon Oct 04, 2010 8:13 am ] |
Post subject: | Main wheel hub bolt torque settings |
I have had a look through my owners manual and i cant seem to find what i should torque the main nut on the wheel hub up to?? any help would be greatly appreciated!! |
Author: | drmini in aust [ Mon Oct 04, 2010 9:12 am ] |
With drum brake CVs it's 60lb/ft then align to the next pin hole. With disc brake CVs (Cooper S onwards) it's 150lb/ft then align to the next pin hole. |
Author: | MiniMe87 [ Mon Oct 04, 2010 9:58 am ] |
Once again thank you doc! you seem to be a major helping hand in getting this LS back on the road!!! (it was the front end so its the disc brakes) |
Author: | GT mowog [ Mon Oct 04, 2010 1:38 pm ] |
drmini in aust wrote: With disc brake CVs (Cooper S onwards) it's 150lb/ft then align to the next pin hole.
If the (Disc type) CV has two holes through it as the Doc says^ but if it has one hole and a course thread for the split pin it's actually 193 ft/lbs and then to the next hole. |
